Thread: CDTI 150 Intermittent loss of power/judder
    Nov 2009
    Portugal
    Default CDTI 150 Intermittent loss of power/judder
    Hi all
    Well, my 2006 cdti (150), 200K on the clock got a strange problem.
    The problem would appear mainly when i depress the accelerator and below 2000rpm, never above. Mainly when the car have not reached the running normal temp. and most of the times in urban circuit.
    There´s a intermittent power loss, when i accelerate,nothing happens, then i disengage the gear, accelerate in neutral, two ot three times, and the car comes back to normal. If i continue with my foot down the accelerator, the car eventually awakes but only after a couple of seconds(or minutes, should i say) but sometimes not...
    Randomly the spanner light comes on the dashboard but just until the malfunction disappears. There are no registered error codes.
    Already replaced the throttle body, but seemed not to cure the problem.
    Already cheked the vaccum hoses. Have put a fiat gasket on the EGR a year ago with no problems whatsoever.
    What might be?
    Sorry my english...
    Many thanks!
    Nov 2009
    Portugal
    More data....
    Normal maintenance made three months ago.
    Problem appears always under 2000rpm, never above.
    When i accelerate right after i released the accelerator.
    Mostly when the car has not reached the normal operating temperature or when i start the car after a couple of hours stopped.
    Already cleaned boost sensor with carb cleaner.
    Have previously cleaned the EGR and fitted a Fiat blanking plate and gasket about two years ago.Clogged EGR already?
    If i unplug the EGR to test it, the malfunction light on the dashboard can be erased only by "battery reset"? I have no Tech2.
    TKS
    Regular Member Barlow's Avatar
    Jan 2012
    Chester
    Vehicle : Nissan 350Z GT
    Engine : 3.5 V6
    Year : 06
    Mileage : 50,000
    Sound like symptoms of a bad Boost sensor or Camshaft position sensor.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Or the 3rd injector plug, what colour is yours blue or yellow
    Nov 2009
    Portugal
    Quote Originally Posted by merikiito View Post
    The plugs are the new ones.
    Thanks!
    Nov 2009
    Portugal
    Quote Originally Posted by Barlow View Post
    yes, I also thought about that and cleaned the sensor.
    Thanks!
    Nov 2009
    Portugal
    I bought a new(used once for testing purposes)throttle body after cleaning the old one with no results.
    Installed the new one but the problem persisted...
    So I decided to clean the EGR, and guess what, the defective part was in fact... the EGR
    Before:
    After the EGR and solenoid cleaning and some lubrication with WD40 (the EGR was partially blocked/jammed:
    The car it´s OK! Pulls like a raging bull now...
    Many Thanks to you all.
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Well done, and I see you have the same success as me with those gloves!
    Nov 2009
    Portugal
    Quote Originally Posted by Chris B View Post
    LOl
    The gloves are handy...when they not tear.
    Nov 2010
    East Midlands
    Trim : design
    Well done - and your English was very good as well - you should hear my Portugese
  1. Power loss, judder under acceleration
    By JonnyB_UK in forum Y & Z30DT Specific
    Last Post: 14th August 2012, 12:06
  2. Loss of power and engine judder in 5th and 6th
    By gdansk in forum Engine & Drivetrain
    Last Post: 23rd September 2011, 15:08
  3. Intermittent loss of power steering......
    By 1ctchris in forum Suspension, Wheels & Brakes
    Last Post: 17th May 2011, 10:20
  4. 150CDTI - Intermittent total power loss
    By birdii in forum Engine & Drivetrain
    Last Post: 18th April 2011, 22:16
  5. v6 cdti judder/loss of power
    By rickyhopkins in forum Engine & Drivetrain
    Last Post: 12th April 2009, 00:30
vectra c loss of power and steering judder
car juddering and loss of power vauxhall signum
1.9 cdti throttle actuator problem
vectra aircon judder
