Thread: CDTI 150 DMF Clutch part question
    Dec 2010
    somerset
    Default CDTI 150 DMF Clutch part question
    Hi all,
    After looking on the web (using www.eurocarparts.co.uk here) there seems to be two otions for a DMF, one Sachs Part No.: 336720210 @ £258 and one not named Part No.: 336720390 @ £372.
    Now with the price difference are these different fpr a 2006 cdti 150?
    also the clutch kit is the 3 part Luk Part No.: 637723230 one right?
    Ideally id use the cheaper flywheel but ive been told my car needs the
    OEM DUAL MASS FLYWHEEL VECTRA 1.9CDTI 02- Eng.Nr.17361103/04511800->150BHP £371.94 (Part No. 336720390)
    So really confused as I can save some ££££££ getting the Sachs one
    Cheap on www.vauxhallworldparts.com @ £220 for the sachs one also
    My cars been doing this for a while - The noise comes on now when the clutch is at the bite point when its idling. As you press it further down it gets louder, fully pressed it stops and fully released it stop.
    damo.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    sach flywheel will be fine mate.
    the noise is more than likely the release bearing.
    in my v6 i fitted a LUK flywheel and clutch pressure and friction plate with valeo csc
    Dec 2010
    somerset
    so if its just a release bearing i can hold of for a while and do it in the next 6000 miles or 6 months
    notcied the Luk clutch kit includes the CSC
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Tbh false economy stripping that far and not changing the clutch, and flywheel
    Took me about about 9 hours to do mine so not something I'd wanna do twice if I didn't have to
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Dec 2010
    somerset
    good point. ill leave it for a while and get one part every 2 months so its not such a big sting on the finances
    thanks for the help.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Fingers xd it lasts that long mine started makingnnoise and it was about 3 weeks after clutch totally went :-(
  1. 2 Part Clutch Kit 1.9 cdti
    By platty in forum Engine & Drivetrain
    Last Post: 26th February 2012, 20:48
  2. Replies: 19
    Last Post: 18th February 2011, 20:40
  3. Clutch question
    By addyboy1982 in forum Engine & Drivetrain
    Last Post: 18th June 2008, 18:42
336720390
sachs code 336720210
336720210
336720210 sachs
