Results 1 to 10 of 13
Thread: D p f
    scottish region
    Default D p f
    Can someone explain regens etc I know why its there the reason I ask is this morning went a drive some town/bypass when I went to park up it sounded as if the exhaust was rumbling but turned it off anyway then went back out and would not start the spanner light flashed so turned it off and on and it started so took it a long run mpg was crap and stationary was 0.7 its normally 0.1 now after the run the rumbling is away and stationary is 0.1 but there's a burning smell which I'm thinking is the dpf as it burns at 600 f so just to ease my mind I wanted opinions thanks
    morecambe
    35 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Just forces the crap out mate by heatin it up very hot
    scottish region
    Yes but does what I said sound like a regen
    scottish region
    Anybody
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    It does sound like the regen especially as your instant went to .7
    scottish region
    Thanks I though it was
    PRESTON
    Are you sitting comfortably,, then i shall begin, grins...
    Basically what is happening during this process, is that the engine's computer has decided from the information that it receives from the sensors installed in the exhaust, that the DPF has filled up past its acceptable limit. The computer then closes the EGR (exhaust gas recirculation) to help get exhaust gas temps higher and also injects a small shot of fuel into the cylinders when the exhaust valves are open, hence increase in fuel consumption. The raised exhaust temps, up to 600 degrees Celsius, and the small amount of fuel then burn out the particulate (soot) that the DPF has collected since its last regen.
    Once regeneration starts the ECU then needs to see the correct value readings from the pressure sensors in the exhaust that the filter is flowing an acceptable limit again, it ends the regen cycle. It is not good practice to switch off any car whilst the regen process is running it’s cycle. Typically if this happens, the car will attempt another regen the next time the engine is started and reaches temperature. Problems arise after several interrupted regen cycles, this causes the DPF to block, bringing on the EML and entering limp mode. Quite often the car will no longer attempt another and usually needs a forced regen via tech2 or similar, however a hot fast motorway run at 70 in 5th may force a regen and clear the problem. During this run, observe the instant mpg which will be very low as the regen takes place and rises to expected levels, once regen is complete.
    The main factors causing DPF issues are short cold runs, faults in the vehicle fueling system or using the wrong specification engine oils.
    PRESTON
    Annnnndddd a double post, grrrrr
    scottish region
    Thanks mate that answers everything I take it the exhaust gets loud as the egr valve is closed
    PRESTON
    Your very welcome. The exhaust note does change, but as you have seen, the big giveaway is the fuel consumption and sometimes you can actually smell the heat from the DPF.
