Thread: Air filter fixing
    Regular Member keith1983's Avatar
    Sheffield / Spalding
    Vehicle : Vectra 1.8 SRi
    Engine : Z18XE
    Default Air filter fixing
    I have a generic induction air filter that I've jubilee clipped onto my air flow sensor and I will be playing aeround with some hose to try get a cold air feed to it. How have people fixed their filters in place as mine just kind of sits there where the oe filter house used to be and rattles around a bit? Any pics of how people have fixed theirs in place would be great.
    Engine : Z18XE
    Has nobody come up with an ingenius way of fixing their air filter? Does everyone just leave them flapping around?
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    on ym old b i tried a k&N 57i and just left that flapping about although it didnt really.
    i think most people on here use panel filters tbh.
    no doubt now there will be a flood of posts from people with induction kits!
    Dec 2011
    Seaham
    Cable ties? Can be used to tie almost anything down or up or to the side!
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Quote Originally Posted by keith1983 View Post
    Well, as mentioned a replacement panel is what most people go for.
    However I think some sort of l bracket made from mild steel or aluminum.
    You can then Jubilee clip to the Filter and bolt to the body work.
    Has it got a housing, or are you letting it breath from the engine bay? It'll make a mean noise though with it being open..
    Matt
    Engine : Z18XE
    It ismpositioned fairly close to the standard air inlet so has some cold ish air getting to it. To be fair if I wanted performance I've got the wrong engine!
    Feb 2012
    Calne UK
    Fair enough I suppose, but my point being is that you might actually decrease performance with warm engine bay air, however there will be more air entering the engine with less resistance, so it might offset. Nice shiny alli pipework would really help
    Anyhow, back onto the fixing. I used to use cable ties but it's a bit "barry".
    A bracket that you can fasten between the jubilee clips and the filter would be your best bet... If it's light metal you bend it to suit the contours.
    Matt
    Engine : Z18XE
    I was thinking of getting some thin sheet metal and like you say bending something to suit and then a combination of jubilee clips, rivets or bolts to hold it on. I was a fitter in a past life so if I can get my hands on some material it shouldn't be too much of a problem to do! Getting some ducting to exactly the right place that looks good can be difficult though! Although drain pipe is exactly the right diameter for the inlet of my filter so I might bodge something out of that and then try and make it look nice!
    wirral
    27 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    I had simota induction kit on my Astra an bracket came with.
    But will give you an idea of what to make.
    It just bolted to slam panel and secured to filter with a jubilee clip
    wirral
    27 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    D.p aarrgghh
  1. is it worth fixing
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2012, 20:45
  2. Splitter fixing?
    By Steven in forum Styling
    Last Post: 3rd March 2012, 05:23
  3. Car Mat Fixing clips
    By cap27 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 14:47
  4. Fixing Sub Grille?
    By parapaul in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2007, 00:33
  5. fixing maybach
    By jacenty in forum Comedy & Humour
    Last Post: 16th February 2006, 00:40
