Results 1 to 10 of 13
Thread: How hard is it....
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Default How hard is it....
    To remove the trims from the dash and door cards?
    At the moment I have the Woodgrain/walnut effect and want something that looks a little more...."Modern?" Mine is an '02 Elite, my dad has a '55 facelift Vec and I quite like the ones in his, the usual sort of granite/grey trim but with an aluminium strip on the passenger side of the dash, was going to get this set instead, have the grey/granite part painted the same colour as the car and leave the aluminium piece as it is, but are they hard to remove and does anyone have part numbers and/or round about prices as to how much this would cost?
    The dash one's just pop out... the door trim one's thou, appear to be bonded on to the doorcards.. you'd be a braver man than me to try and remove them..
    Regular Member Harry's Avatar
    Uxbridge, London
    exactly what i wanted to do too....but alas, it's almost impossible with hacking the doorcards to death!!
    or buying complete new doorcards!!
    I thought Beavis has done this? IIRC they are 'riveted' onto the door cards i.e. plastic lug on the trim part pushes through hole in the card as is then squished on the other side (like a rivet is) to hold it on. All you need to do is grind the splayed plastic bit to release the trim strip and then work out a suitable way to fix the replacement trim.
    Uxbridge, London
    but the trim on the door does not have an indivdual part number - it's all part of the doorcard. i might be wrong but i was looking at the screen when the guy was searching for it.
    True Harry, so he'd need to get them from a set of donor door cards - that's what Beavis did IIRC. He had a donor set of cards and swapped them over to the ones he put in the car - it was all when he had most of his leather interior (and some trims) nicked out of the car and he fitted a replacement, but he needed/wanted to swap the door card trim.
    Uxbridge, London
    aha - all makes sense now.
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    dead easy to remove and refit the trims on the door cards as Duncan said grind off the plastic lugs and they pull off
    you could then paint the trims and refit I bonded them on and used 5mm rivets back in the holes (perfect fit) and have had no issuses at all with them since and you wouldn't know they have been changed
    Ah perfect - from the man himself! Cheers Beavis!
    Regular Member Gazza90000's Avatar
    Newcastle upon Toon
    [quote=Kev_A;197554]To remove the trims from the dash and door cards?
    quote]
    Mad Geordie person !
  1. how hard is it
    By leedslads in forum Electrical & ICE (including SatNav)
    Last Post: 8th August 2012, 21:53
  2. Insignia Anyone know how hard it would be to fit this?
    By Mark Evison in forum Insignia car chat
    Last Post: 8th April 2012, 00:21
  3. How hard could it be?
    By n_hudson in forum Suspension, Wheels & Brakes
    Last Post: 31st January 2010, 14:51
  4. How Hard Is This
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2008, 15:50
  5. Die Hard 4
    By GSIPETE in forum General Chat
    Last Post: 16th July 2007, 18:41
