Thread: What would cause the suspension spring seat to rub against the car?
    Regular Member Innes's Avatar
    Plymouth
    Default What would cause the suspension spring seat to rub against the car?
    Hi folks,
    I've been getting a weird knock sound when on full lock and when the steering wheel passes through center.
    When I brake, especially down hill, I can can hear creaking coming from the front.
    I had it in for its MOT (which passed - just) and I asked him to look for the cause. When I picked the car up he said the the Suspension Spring Seat (the bit that the bottom part of the spring sits on) is rubbing against the inside metal work. He had asked if I had had a frontal impact which I hadnt. He thought the impact might have pushed the metal outwards towards the spring. His solution was to put a broom handle on the metal work and hammer it away from the spring seat. Not quite what I was expecting.
    It has quitened down a bit but still rubs on full lock and creeks like an old man under breaking.
    The anti-roll bar bushes were replaced last year along with the drop links. He said they still looked in good nick.
    Has anyone got any idea whats happend to my suspension??
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Are you sure the creaking isnt from the brakes? Also the bottom of one of my springs had snapped, but it was inside a plastic sleeve so you couldnt tell, this would shift the position of the spring.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Could you post a pic of where it's been rubbing? There is an abs sensor cable in the same place that can rub and it makes it look like the struts been rubbing. Had this on my last vec
    It could also be the strut top bearings as they can knock when they get worn
    Plymouth
    I've tried taking a photo but it's a bit to dark. I'll have to jack it up and take the wheel of to get a proper look.
    I am here: http://tapatalk.com/map.php?jxvz3j
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 98000
    could the actual rod of the damper unit in the strut be bent from some inpact, I have had this once causing groaning noises and was only found when I stripped the whole front end down including taking off the springs to check the top bearings and when I checked the rod of the damper it was slightly bent with marks on it where it was going in and out the damper unit. hth
  1. spring seat mod
    By denzilbud in forum Vectra C / Signum Car Chat
    Last Post: 5th September 2009, 19:17
  2. Spring Seat Mod
    By andy13 in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2009, 18:44
  3. Some Help With Spring Seat Mod Please..
    By Thomas1 in forum Vectra C / Signum Car Chat
    Last Post: 14th September 2008, 20:56
  4. spring seat mod
    By selv1980 in forum Vectra C / Signum Car Chat
    Last Post: 11th May 2007, 13:30
  5. Spring seat mod
    By Kcs in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2007, 12:48
