Thread: Where's the diagnostic port & can you get Software to hook PC up to car ?
    Regular Member muffking's Avatar
    Default Where's the diagnostic port & can you get Software to hook PC up to car ?
    Hi guys.
    I was wondereing where the diagnostic port is on a Vectra C as it was under the handbrake lever on my old Vec B.
    Also has anyone got PC software to hook my laptop up to the car with, as I've got an OBD2 lead that I use to connect my notebook to some VAG-COM that allows me to read and write from PC to my VW designed Ford Galaxy and wondered if I can use the same lead to fix problems.
    Feb 2006
    Dorset
    Under the ash tray
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    And yes there is a tool and program. All I know it starts at £95 and was in Total Vauxhall last month.
    Cheers guys. Anyone got a copy that I could try my lead with. I'd be happy to diagnose a few problems if it works mith my cable.
    Regular Member sig63's Avatar
    Belgium
    Vehicle : Opel Insignia
    Trim : Cosmo
    Engine : 2.0 CDTI
    Year : 2011
    It's called Opel/Vx TIS and there are plenty on it on ebay... original and cheap polish copies (but not sure if it is legal if you don't register, and for what you want it, I suppose the hardwarekey is needed)
    Vehicle : SRi
    Mileage : 137000
    Regular Member Paddy2bsure's Avatar
    Hertfordshire
    Quote Originally Posted by sig63 View Post
    Does anyone know if it's a different system to the Saab TechII? I can get these easier!
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Same protocol different software,
    Well it turns out that after using loads of software, the standard cable is an ELM type and not a direct OBD2 interface. So it's off to Ebay again then
  1. diagnostic software
    By veralum in forum Suspension, Wheels & Brakes
    Last Post: 25th January 2010, 10:55
  2. where is the diagnostic port on a corsa c???
    By big rich in forum The 'Off Topic' room
    Last Post: 4th September 2009, 17:48
  3. diagnostic port
    By m1ke823146 in forum Engine & Drivetrain
    Last Post: 12th August 2009, 20:52
  4. OBD Diagnostic port location
    By DTGB in forum Petrol Engine related
    Last Post: 10th September 2008, 11:46
