Results 1 to 3 of 3
Thread: 2004 vectra power steering pump problem
    Mar 2012
    LEIGH, LANCASHIRE
    Unhappy 2004 vectra power steering pump problem
    i recently topped up the fluid in power steering pump and after a drive round it seemed ok... parked up on drive and cleaning up and thought i heard a pop like a fuse blowing, got in car to start and the dreaded steering wheel with exclamation mark showing and no power steering available.... spoke to friend and advised the power steering pump has probably shorted and needs replacing... i have sourced a part and was wondering if anyone can advise on how to go about replacing part... is it a common fault these going???? i did look at the fuses and all look okay are there any other in line fuses which could have blown or is it a definate that the pump needs replacing????
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Hi, Helps if you tell us what engine you have - Power steering faults are quite common and there are loads of posts giving details - can be a sign your alternator or battery is on the way out which prevents the power steering working. Another problem can be the heavy duty wiring connector plug on the motor becoming corroded or loose - remove it and clean and then reconnect.
    If you do have to replace the motor it has to be programmed to your car using Tech 2
    Nov 2010
    East Midlands
    6 Post(s)
    Trim : design
    Double posted for some reason
  1. Power Steering Problem Pump/Sensor
    By Jimbob SXI in forum Suspension, Wheels & Brakes
    Last Post: 31st March 2017, 09:34
  2. Power Steering Pump ECU communication problem.
    By otis_b in forum Engine & Drivetrain
    Last Post: 19th January 2012, 11:16
steering pump fuse opel vectra c
vectra c power steering problems 2004
opel vectra c power steering pump fuse
