Results 1 to 10 of 14
Thread: Ive had the dash in bits
    Regular Member pipamish's Avatar
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Default Ive had the dash in bits
    Ive had the dash in bits this morning trying to figure a way to put my gps antenna on top of the dash like Chrisvectra has done well with great results i have done it and i now dont lose my signal like before has it was buried at the back of my cd70.
    Upon having a look i have been wondering if i could route it up the a pillar through the roof lining and put it somewhere behind my roof light what do you guys think do you think it will work
    Regular Member J P S's Avatar
    Sep 2011
    Birmingham
    Vehicle : 2007 1.9cdti sri 150 estate
    Trim : sri
    Engine : 1.9cdti 150
    i have thought about this too but i am not sure antennas get a good reception through metal so it would have to be on the glass somewhere i think.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    My GPS antenna sits ontop of the centre speaker on the dash under the cover so you can't see it. There's a gap straight through between the vents for the cable to go to the back of the head unit.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Ive got the speaker there and i have no gap whatsoever mate been trying to figure a way to route it im not to keen on it being on top of the dash so i will figure a way of solving it whether i can route it and stick it somewhere hidden behind the rear view mirror
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    No gap? Weird, mines sitting on top of the speaker (you can see it in the pic) and there's gut loads of space. Do you have a different speaker fitted other than standard perhaps?
    Full Member
    South West
    Mines exactly the same as Ian's - Mounted on top of the speaker. Only fiddly part was getting the blue fakra connector down into the space behind the dash to get to the back of the CD70.
    I used a metal coathangar and taped the connector to it and wiggled it through eventually.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    I have felt all around with my finger and i cant feel a hole at all i do have the factory fit bluetooth and i believe thats the speaker that sends out the voice and part of my 7 speaker system
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    The gap isn't really visible because of the angle you have to have your head at, if you take the centre dash vents out you'll see daylight if you look through.
    In order to run the cable you need to lift the speaker at least partially out as the gap is big enough for the cable but not the plug, so you lift the speaker up, feed the plug through and then screw the speaker back down again.
    It's fiddly but the best place for it in my opinion.
    Maybe the factory bluetooth speaker is much bigger than the standard centre speaker I don't honestly know as I don't have the factory bluetooth.
    wolverhampton
    Trim : Sri
    Engine : 2.0 turbo
    Cheers i will take another look
    Regular Member krazylegz's Avatar
    South Shields
    The gap is in the rear left hand corner as you look at it
  1. Facelift Dash Trim on a Pre face dash?
    By jordib in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2013, 22:15
  2. Wiring - Dash loom/cables behind whole Dash
    By Dane-10 in forum Electrical & ICE (including SatNav)
    Last Post: 6th January 2013, 10:49
  3. Dash on, dash off Daniel Son.
    By krisby in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2011, 18:38
  4. how can I, Piano black dash bits?
    By Robbie69 in forum Styling
    Last Post: 14th March 2009, 04:27
