Thread: Bouncy bouncy
    Glasgow
    Default Bouncy bouncy
    Vectra C 06 LS. MOT last week and sailed it apart from a rear tyre change. Since then the car has felt a bit bouncy to drive, even on decent roads driving alone, feels like driving in a light wind moving side to side. Checked tyre pressures and all ok. Just wondering if a suspension check would be worth it or is there something specific to target first to sort. Also think I feel a slight understeer or that may just be me adjustign to the side to side movement. Any advice would be greatly appreciated.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    21 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 221,007
    Sounds like your shock absorbers are not working properly. Try bouncing each corner of the car in turn. If you push down on the car and release the pressure, the car should return to its start position with minimal bouncing - upwards and downwards oscillation. I think one or two single up and down movements are permissible. Any more and the shock absorbers need replacing.
    Look here: http://www.aa1car.com/library/ride1.htm
    The MOT test centre ought to have picked up on that fault.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Jun 2011
    Herts
    sounds like shocks on the way out.... but may be rear upper control arms as they allow swaying if the are worn.
    you need to grab the top of each rear wheel, with hands inside the arch and pull it towards you hard and fairly quickly. if it moves then they are shot. you may hear a clunk as they fall back into place too.
    HTH
    Glasgow
    Thanks for the advice guys. Done both the corner and wheel tests and all seems fine. Will keep looking for now.
  1. Bouncy ride
    By Dan206 in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2013, 15:23
  2. Bouncy Rear
    By mon in forum Suspension, Wheels & Brakes
    Last Post: 20th January 2013, 14:31
  3. Bouncy, bouncy, bouncy.
    By kenbo in forum Suspension, Wheels & Brakes
    Last Post: 4th January 2012, 16:10
  4. bouncy car
    By jools in forum Suspension, Wheels & Brakes
    Last Post: 10th March 2007, 10:00
  5. Bouncy Bouncy
    By Stringlabel in forum Handling & Braking
    Last Post: 1st February 2007, 12:33
