Results 1 to 10 of 17
Thread: Pulse Ratio Boost Pressure Solenoid Valve
    Feb 2011
    lisburn
    Default Pulse Ratio Boost Pressure Solenoid Valve
    Hi guys, my opcom tech 2 shows the above at 64 percent and no higher is this normal?
    Feb 2011
    lisburn
    bump
    Feb 2011
    lisburn
    car is throwing up fault code
    P0105 - Boost Pressure Sensor Circuit High Input
    (07) - Not present
    Feb 2011
    lisburn
    anybody any ideas?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Try bumping the thread in about 2 hours mate, most guys will be home and online then.
    Regular Member firefox007's Avatar
    Zagreb
    Quote Originally Posted by iwtand View Post
    (07) - Not present
    http://vectra-c.com/forum/showthread...36#post1715036
    Feb 2011
    lisburn
    had car on opcom also got code P0380 - Glow Time Relay Circuit Malfunction
    (00) - Present. picked up a secong hand one and fitted and still same code any ideas on this one
    Feb 2011
    lisburn
    Feb 2011
    lisburn
    cmon guys surely someone has an answer
    Feb 2011
    lisburn
  1. how can I measure boost, air mass and air-fue ratio
    By Caveman_nige in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 12:59
  2. Oil Pressure Solenoid Switch
    By masj78 in forum Engine & Drivetrain
    Last Post: 1st January 2011, 13:19
  3. What is a boost pressure valve
    By darveccy_c in forum Introduce yourself.
    Last Post: 1st January 2010, 23:52
pulse ratio boost pressure solenoid valve
pulse ratio boost pressure solenood valve
pulse ratio boost solenoid valve
