Thread: clicking behind glovebox..
    Aug 2011
    north wales, criccieth
    Default clicking behind glovebox..
    when i turn on the ignition there is a loud clicking noise from behind the glovebox... there was no noise when i brought the car but i was wiring in a sub and removed the glovebox to run the clables and found a plug hanging... since if plugged it back in its making a horrible noise. if i didnt plug it back in a wold never have noticed... what does it do and what part is it that is brroken and where can i get it from..
    cheers guys
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Air recircultion flap motor slips
    Regular Member themarbleman's Avatar
    sussex
    . Mine went a couple of years back, you have to be a contourchinist to change it,very awkward but with patience you will be fine.
    Aug 2011
    so can someone find a link to what i need to fix itfrom ebay or a vauxhall part number or something...
    you say recirc flap as motor slips, but is it the flap i need to replace or the motor? what do i search for?
    want a cheap as possible fix and iv found ebay always produces the cheapest parts so far..
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Quote Originally Posted by mattv6diesel View Post
    Mine decided to go south on me last month
    One of the teeth on the gears inside had sheered off.
    More here:- http://www.vectra-c.com/forum/showthread.php?t=138933
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Aug 2011
    http://www.ebay.co.uk/itm/Vauxhall-V...item35b445a02a
    would this be the part i need then? or do i need extra bits... also there seems to be a few diff part numbers but all parts look the same... some say they are for semi automaticor electronic climate control and some are just for electronic climate control.. how do i know which one is for my car. its a 2004 1.9cdti sri 150 spec..
    Aug 2011
    anybody????
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Year : 55
    Mileage : 92,000
    Already replaced:-
    Alternator,
  1. clicking from glovebox
    By skutters in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2010, 22:12
  2. Clicking from glovebox effects electrics
    Last Post: 9th June 2010, 13:15
  3. Loud Clicking From The Glovebox... Help !!!
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 19th April 2009, 21:04
  4. Glovebox
    By Damian in forum Vectra C / Signum Car Chat
    Last Post: 29th August 2008, 10:22
  5. DVD in Glovebox
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 25th March 2007, 21:14
vectra c clicking from glove box
