Thread: Signum 2.8T common faults?
    Regular Member bbdp's Avatar
    Feb 2012
    Essex
    Default Signum 2.8T common faults?
    As the title suggests I'm curious what to look out for? I hear everything fairly bulletproof as long as the service history is complete?
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Suffers the same dodgy fuel gauge as the GSi ....
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Limpmode if u run it on **** petrol best stick to 99 Ron stuff
    Glasgow
    Never had any problems with any fuels.
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Only light after 1 1/2 years and 14,000 miles is the fuel light
    Mar 2011
    Kent
    I've had mine for a year and 23,000 miles later its still going strong with no faults.
    Jan 2006
    Norfolk
    Well mines not a Signum but a 2.8T Elite, now over 125,000 and no major enine faults at all, I had the auto box changed at 53K as Vx feared an ingress of water as on the earlier models but I suspect that the water loss was down to the split header tank that was subject to a recall some while ago.
    The only other problem I have had is that it fails to start when filled up fully in a petrol station, this may be the EVAP system but it passes all the TIS tests and i am not prepared to spent a great deal just replacing parts on spec.
    Jan 2006
    Norfolk
    Well mines not a Signum but a 2.8T Elite, now over 125,000 and no major engine faults at all, I had the auto box changed at 53K as Vx feared an ingress of water as on the earlier models but I suspect that the water loss was down to the split header tank that was subject to a recall some while ago.
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    The speedo seems to rise rapidly ..and the petrol gauge seems to fall rapidly ..other than that ...no problems at all ..oh apart from ...how many times you have to tell ppl what car it actually is
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Lovely engines these.. Just had a days work on chrisvectra's (see my other thread) and its also a nice engine to work on.. Bit of a fiddle to change the rear spark plugs but apart from that
    Re faults.. Not really seen many TBH for these.. I had a Saab in (same engine) that I was working on that had a weak actuator so the boost was trailing off to quick, and also a split boost pipe on a different saab (same engine).. but apart from that, keep the oil fresh with 5w30 GM stuff, keep the coolent correct and use the normal turbo rules (let it warm up before ragging it, dont rag it and then turn car off straight away etc etc ) and you should have a lovely car
  1. Common Faults.....
    By Bainie in forum Vectra C / Signum Troubleshooting
    Last Post: 28th November 2017, 13:25
  2. What are common faults on a 2.2 SRi Direct Automatic....
    By Vectra Adz in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2012, 21:26
  3. Common faults
    By welshboy in forum Vectra C / Signum Car Chat
    Last Post: 16th January 2011, 22:56
  4. Common Faults 1.9 CDTi (150)
    By Chappers. in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 21:56
  5. 2.0 DTI Common Faults?
    By antowns in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2010, 09:10
vectra 2.8 v6 turbo common faults
signum 2.8 v6 turbo common faults
signum 2.8 v6 common faeults
signum common faults
signum 2.8 turbo probloms
vauxhall 2.8 v6 turbo engine problems
