Thread: Brake bulb failure flashes and then goes away
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Brake bulb failure flashes and then goes away
    So - on our CDTI (2005) - sometimes when you break you get the bulb symbol in the dash and on the computer screen it shows you that your passenger rear brake bulb is out.
    But - its not, and brake again and the bulb symbol disapears. This only happens every now and again.
    Ive cleaned all the rear brake bulb holder contacts and plug with contact cleaner and a wire brush. Ive also made sure that the contact spring piece in the bulb holders is up high etc.
    Any other reason that can be causing this. Brake bulbs are not that old so not tried another new set yet??
    Dec 2011
    Seaham
    Try a different branded bulb?
    PRESTON
    As suggested, try another bulb. Usually when this happens, it's warning that the bulb is going to fail soon. I had a similar issue with the front sidelight, got the warning, but the bulb was working. A week later the bulb failed, replace with new and all is now fine.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Quote Originally Posted by barney490 View Post
    Hmm - ok - will try another set.. these were Bosh - but lets see... Prob go to VX and get em
  1. High level brake light flashes on and off?!?
    By frankiebdv in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 20:29
  2. Bulb failure.
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 31st August 2010, 10:47
  3. Bulb Failure Notification
    By WeDesign in forum Electrical & ICE (including SatNav)
    Last Post: 1st August 2010, 15:35
  4. bulb failure light
    By paulzvectra in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 20:03
  5. bulb failure
    By jbr in forum Electrical & ICE (including SatNav)
    Last Post: 27th May 2006, 17:11
