Results 1 to 10 of 15
Thread: Tyre pressures
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    Default Tyre pressures
    As above what pressures do you run on 19" rims
    wales
    Petrol or diesel? I have 32 all round usually.
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    1.8 petrol 57plate
    wales
    Yeah generally put 32 all round in petrol cars, unless the car's full with you.
    falkirk
    I have seen 39 fronts and 35 rears,seemed high but found a few places stating these figs and am running mine at those pressures?
    Regular Member VXR Shaneo's Avatar
    Aug 2011
    Scunthorpe
    Quote Originally Posted by frigosolver View Post
    +1 that's what I have in mine
    Jul 2009
    Wiltshire
    I check and inflate to 40psi front and rear.. 1.9CDTi 150
    According to my manual the 1.8 petrol should be psi and (bar)
    Front 39(2.7) Rear 35(2.5) for up to 3 people
    Front 41(2.8) Rear 48(3.3) Fully loaded..
    was always taught , double the rim size for fronts and rears 3 psi less....
    Nov 2011
    Oxford
    Vehicle : Sri xp1
    Engine : 1.8
    I have 36psi all round but it bangs your teeth out
    Jun 2011
    Herts
    tonyo- I'd check youir manual as mine is a 2.0dti elite- about the same as a cdti...
    normal load 35 front 35 rear
    fully loaded 36 front 42 rear
    Chewy- I'd think 32 would be near the mark for a 1.8 petrol
    pressure is calculated based on weight of car and not rim size and tyre profile.
    so I'd check what the pressure is for 17 or 18 rims in your manual and go with the same pressure as that will be right.
  1. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  2. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  3. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  4. 225/40/18 Tyre Pressures....
    By BigMan in forum Suspension, Wheels & Brakes
    Last Post: 24th November 2007, 22:23
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
