Thread: 2 litre Dti no power
    Engine : 1.9 CDTi
    Default 2 litre Dti no power
    I will be looking at a friends car at the weekend that has no power.
    I had a quick code read but there were no codes at the time so took it for a quick drive.
    No engine management lights but it feels like the turbo isnt cutting in. I could 'rattle' the actuator rod a bit. Is that normal?
    Is there anything to look out for?
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Split boost pipe mate common problem on the dti the Pipe at the front right side that goes to the intercooler had it with my old dti
    Engine : 1.9 CDTi
    I cant hear any leaks but will check.
    Can/should you hear the turbo spool up?
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Ye mate about just under 2000 mine used to start spooling
    Regular Member AKeeNShoT's Avatar
    South Shields, T&W
    Turbo vacuum pipe, one of the rubber elbows will have split, the turbo just stops working, no lights on the dash (well not when the turbo stops but when it first started happening limp mode and spanner would've popped up) and no power, just masses of fuel consumption!
    Engine : 1.9 CDTi
    I have access to a smoke machine so will bung that up one and see if there are any leaks.
    I did have a chick check but didnt see any obvious splits but will have longer this weekend.
    Engine : 1.9 CDTi
    Quote Originally Posted by AKeeNShoT View Post
    Spot on.
    Turned out to be one of the the straight joiners that goes to the valve/sensor on the slam panel.
  1. 5p a litre off V-power all day today !!
    By peelmeister in forum General Motoring Chat
    Last Post: 14th February 2012, 22:21
  2. petrol for 12.9p a litre
    By fingers66 in forum General Chat
    Last Post: 3rd April 2011, 12:14
  3. 6.75 Litre Turbo!!!!!
    By Stephen S in forum The 'Off Topic' room
    Last Post: 9th May 2009, 21:31
  4. £1.99 a litre !
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 18:24
  5. 2 litre or not 2 litre
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 23:12
