Thread: 1.6 / 1.8 VVT Engine
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Default 1.6 / 1.8 VVT Engine
    Can someone confirm that these are essentially the same engine ?
    Looking at cam locking tools on the internet. Many adds specify 'for 1.6' but it looks like the same OEM number - KM6340 is applicable to my 1.8 VVTi
    Perfectly happy to tackle the belt - did several on my old Cavalier 2.0 16V Eco, but just want to make sure I have the right tools for the job - I once saw someone that didn't, and that was messy
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Yeah the z16/18 xer look and basicaly are identical
    Mar 2011
    belfast
    Wink
    i done my timing belt and camshaft oil seals and crankshaft oilseal on my z18xer and it turned into a nitemare so be very carefull as the cam pulleys dont have a woodruff key or locating pin on them like in a z18xe engine, so if you remove the pulleys off the camshaft, you will have to remove the cam cover and place a 4.5mm thick piece of flat metal across the camshafts to lock them in TDC POSITION, the haynes manual for 2005 to 2008 vectras shows you how to do this in more detail in section 2a.8
    i would also reccommend you use the cam pulley locking tool that comes in 2 peices because of the lip on one of the pulleys, ebay item number 230532067670.
    good luck and lets know how you get on.
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    Cheers - yep that's the tool I've gone for, the two part one.
    Don't plan on removing the pulleys, so hopefully shouldn't be too much of a problem
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
vauxhall vectra c 1.8vvt locking cams
