Thread: OK, questions on braking, flexi pipe, suspension, wobbling...
    Regular Member SarahP's Avatar
    Nov 2011
    Buckinghamshire
    Default OK, questions on braking, flexi pipe, suspension, wobbling...
    Hi I have a 2004 vectra estate 1.9cdti (120)
    Just a few questions
    1) In the morning , usually when damp, cold.. i go over bridges or speed humps I get like a loud creaking noise from the front.. later in the day or in the summer I dont get it.. Its everyday in the autumn/winter.. what could it be??
    2) How much is a wheel alignment? My brother is a bus mechanic and he replaced my driver side track rod end and both rear upper suspension arms at weekend, all what that replaced was because we had an MOT advisory on them.We did have a wobble feel when driving slowish but i havent drove the car since so not sure if these have solved it.. will report bk on that tomorrow!
    3) I have exhaust smell in car and when I change gear i can hear a whoosh and sometimes a noise (like u hear planes in the sky) My bro checked it this weekend and said our downpipe flexi is blowing.. are these easily changeable? I have seen on euro car parts that i can get it for £43, the section that has the flexi pipe in and bolts each end somewhere (i assume to rest of exhaust).. are they really that simple?
    4) when I start the car in the morning I briefly hear a noise.. sounds abit like birds.. but then goes.. what could this be??
    5) BRAKEs.. we keep having to bleed our brakes.. had new front ones put in about 12 months ago and since then we keep getting air in them, has brake lines looked at and they seem fine, what we have noticed recently is that the brakes are fine for a while until we get the traction control light come on (randomly and sometimes when sitting) then after that the pedal slowly starts to travel til we have to press again to get hard, then we bleed them.. we are NOT losing any brake fluid though .. any ideas???
    thanking you all in advance
    Sarah x
    Nov 2011
    Buckinghamshire
    Ahh just remembered.. to add to the creaking.. when by bro jacked the car up few months ago it was fine going up but when he was putting it back to the ground it creaked.. loudly! .. I presumed its the same that is creaking when going over humps & bridges.. any ideas??
    Nov 2011
    Buckinghamshire
    hello.. anybody??
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Hi, yes the flexi pipe really is that simple, 3 bolts either end of the flexi section. However, i would recommend soaking the bolts/nuts with WD40 or similar for a few hours prior to trying to undo them. The nuts on mine were siezed solid and one rounded off when i tried to undo it.
    Nov 2009
    Warwickshire
    5.Brakes......
    p { margin-bottom: 0.21cm; } I had the very same problem with a previous car. My pal (a designer with Lockheed Brakes) told me that all car braking systems have become difficult to bleed. So the best way is to use a pressure kit. So I used a Gunson Eezibleed. It was easy to use and cured the sinking pedal problem.
  1. Ok questions on, brakes, flexi pipe, wobble, suspension ..
    By SarahP in forum Vectra C / Signum Troubleshooting
    Last Post: 7th March 2012, 01:00
  2. flexi pipe
    By datiger79 in forum Engine & Drivetrain
    Last Post: 18th January 2012, 17:27
  3. flexi pipe
    By unreal_event_horizon in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 23:28
  4. Exhaust flexi pipe
    By andsaw in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2011, 18:41
  5. flexi pipe
    By cookiejar31 in forum Petrol Engine related
    Last Post: 23rd August 2008, 19:20
