Thread: Starting to pull out my hair
    Jul 2011
    Halifax
    Unhappy Starting to pull out my hair
    The subject :Vectra c 2.2 dti estate
    The Problem:Wont start when left for 6 hours (starts fine first thing)
    The solution: erg valve cleaned,diesel drain off pipes replaced inc t pieces,New battery (correct for the car) new starter moter (2 months old),new ecu temp sender,new glow plugs (vauhall ones).
    It failed to start today at work and had to hitch a ride home
    My mechanic is now looking at injecters he is going to remove them and have them tested and cleaned replacing the seals when he reinstalls them
    Anyone have any more thoughts on the matter ??
    also just add when it was difficult to start I had lots of white smoke smelling of the heavy oil fuel ...I am now starting to think it could start to get expensive also there is no fault codes being displayed
    many regards
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Is it cold? Dads had a slow starter that didn't help but after replaced fault still there when cold, so i wired in a switch to turn on the glow time relay and glow plugs when it was cold.
    Jul 2011
    Halifax
    Outside air temp today accordinding to the car was 17.5
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    17.5*c where? it never got over 10*c in weymouth. It made a difference in dads much better cause they don't use the glow plugs enough
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Not had this iin a diesel, had a petrol Celica once, would star fiorst time every time cold or hot, but do 1-2 miles so it was half warm, and it would refuse to restart for 20 mins or so. Mechanic and myself reckoned it was choke/5th injector, put a complete bottle oof redex through it on 1/4 tank of fuel and it sorted it.
    PRESTON
    Syptoms of a failing crank sensor would be bad starting when hot, fine when cold. Might be worth a look.
    Jul 2011
    Halifax
    Mehanic is replacing the injecter seals he seems to think that could be the route of the problems ...he thinks they are drawing air in heres hoping i can not drive this hyudi .....
    Jul 2011
    Halifax
    ty barney I might replace that just as a matter of course
    Regular Member peadar's Avatar
    Aug 2007
    in the glens of Antrim N Ireland
    Vehicle : SRI
    Trim : FULL LEATHER
    Engine : 2.2 DTI
    Mileage : 197,000
    glow plug relay , injector seals ,crank sensor ,fit an inline non return on the fuel line , take the cap of and make sure the egr vale is returning to the closed position have you tried disconecting the temp sensor then put the key in wait 5 sec and start and connect the sensor straight away
    Jul 2011
    Halifax
    glow plug relay tests ok temp sensor has been replaced
    got the car back today £372 quid lighter injecter seals replaced inlet manifolds cleaned all seems ok the test will be in he morning then again at 1 pm lunch time wish me luck.....Mechanic rebuilt it today said it was a pig to start after priming but has started first click all afternoon ..tomorrow is the acid test i have noticed a big difference in power ...
  1. The hair has been shaved.
    By BigWilko in forum Yorkshire (RO - jaguser)
    Last Post: 30th January 2013, 12:49
  2. Hair removal...
    By Big Sig in forum Comedy & Humour
    Last Post: 20th April 2012, 10:43
  3. Slow to pull away - dangerously slow to pull away (150cdti auto)
    By the1theycallthe1 in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2012, 21:10
  4. Replies: 53
    Last Post: 22nd September 2008, 09:32
  5. Some hair dooooooo
    By Big Davie in forum Comedy & Humour
    Last Post: 3rd July 2006, 11:32
