Thread: Engine Starts - no Revs
    dunstable
    Unhappy Engine Starts - no Revs
    Got a Vectra C 3.2 elite - starts, but on depressing the
    accelerator pedal no power/revs. No engine fault lights on.
    Mar 2012
    kent
    Sounds like one of a few things.
    Fuel filter could be blocking up.
    Injectors may need cleaning.
    Or
    At the worse, ful pump may be on its last legs.
    Mar 2012
    kent
    Or
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Will it actually move forward when you lift the clutch? Possible that the electronic pedal unit that has failed.
    dunstable
    Thanks for the info, sorry should have mentioned it is an automatic.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Sounds TPS Could do with seeing if you can get a reading from it
    Regular Member thefibreguy's Avatar
    bedford
    Are you sure you not pressing the brake?
    Sorry about that, I did not have anything constructive to add, but just wanted to take part.
  1. Replies: 5
    Last Post: 13th May 2012, 18:58
  2. Engine cutting out low revs
    By SHiiBBY in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 12:26
  3. engine starts then dies!
    By distuio in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 20:55
  4. 2.2 direct engine starts cold but doesn't warm?
    By barnesy in forum Engine & Drivetrain
    Last Post: 19th December 2010, 12:09
  5. Engine starts then Dies
    By Mini the Minx in forum Engine & Drivetrain
    Last Post: 21st September 2010, 13:28
