Results 1 to 10 of 18
Thread: led conversion
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    Default led conversion
    almost done just got steering wheel to do now dreadin it. I thought the plcc2s were small. Any hints on doin them would be good.
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by jimbo1987 View Post
    1/2 can steering wheel controls are easy. 3mm dome LEDs. Hardest part is getting them back in.
    Once you've got the unit back together chop off the little plastic locators that poke through the board. Bizarrely enough it will make the connector locate better
    Jan 2012
    southwest
    cheers mate i bought wrong 1s but tink ive still got 3mm domes left from map light buttons
    morecambe
    32 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    What Wilko said he did mine Sunday top job he did aswell
    Jan 2012
    southwest
    mite doit tommorrow night, ive done tid aswell but cant get it same blue its more turqoise, i put blue bayonet fruit machine bulbs in and two layers of milk bottle plastic as a difuser instead of orange piece. Think it looks alrite though
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Yeah, i changed mine to red on my old vec using some filter gels (used on show lighting) was the only colour i could percieve working with the orange diffuser still in there,
    Jan 2012
    southwest
    oh yeah overorderd leds still got 23 plcc2, 10 smd for full can steering wheel, and 2 510 ohms resisters if anyone needs em you can av em
    Ely, Cambridgeshire
    58 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Lol, you think the plcc2's are small, you should try using 0603's. I used those on the GID and the left LCD on the dash on Kman's advice and it does look a lot more even, but those things are tiny (about a quarter the size of a grain of rice each).
    There's four of them lined up in the bottom left corner of this pic...
    Doing the steering wheel controls on a preface is easy though, just make sure you get the LED's round the right way, they're 3mm domes as said and cutting off the locator lugs is good advice although I only cut off the one nearest the centre of the wheel on each and they go back in easy then and still have one of them holding them in place as well as the screw.
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Quote Originally Posted by Ian-Highlander View Post
    I did my steering wheel controls with the 0603's (Scroller type), you're right, nightmare.
    Ian, it looks like you're using lead free solder in your photo? YOU'RE GOING STRAIGHT TO HELL!!!!
    Ely, Cambridgeshire
    58 Post(s)
    Year : 2010
    Quote Originally Posted by BigWilko View Post
    Lol, yup, cheapest of the cheap Maplin best, lead-free solder. It was the first reel I pulled out of my electronics tool box (there's several in there)
    Pah, as long as it flows properly it's fine, biggest issue with it is when people don't let it flow and it causes really brittle joints but on the stuff we're using it for in cars that's not an issue as long as its done right.
    Although I'm not sure what's saddest, me knowing that or you spotting I was using it
  1. Vec C 2.0T LPG Conversion
    By Aidi in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2012, 10:13
  2. LED conversion
    By nicj in forum Electrical & ICE (including SatNav)
    Last Post: 13th November 2011, 00:51
  3. Led Conversion
    By JonesG in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2011, 20:21
  4. HID conversion
    By spooney in forum Styling
    Last Post: 20th January 2009, 20:20
  5. vxr conversion
    By c9rum in forum Petrol Engine related
    Last Post: 10th January 2009, 20:49
