Thread: I think I have fried it but you never know
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Default I think I have fried it but you never know
    I have been doing my led swap for quite a long time. A bit here and there.
    http://www.vectra-c.com/forum/showth...=140667&page=4
    I had this problem on my heater controls since the led swap.
    1 to 4 fan speeds work fine. Hot / cold is fine. All the buttons work but the direction of air flow is very odd. Select each setting and you can here the fans whiz up the the path of air changes but is a lot less power than before. Also the direction of air does not correspond to the selection made.
    I have not tried a spare as of yet but I thought I would post this in case someone has had the same or similar problem and fixed it with a fuse change etc.
    Many thanks
    Regular Member BigWilko's Avatar
    Jan 2010
    Barnsley
    Engine : 3.0 CDTI
    Check that no little flecks of solder have found their way onto the tracks. I had something similar with my recirculate button.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 110000
    I had a similar problem when I didnt seat the plugs properly when refitting it.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Quote Originally Posted by BigWilko View Post
    Thanks mate.
    I'm going to pull it out in a mo and have a good look around the board.
    Fingers crossed I find some thing like that.
    Will let you know
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Thanks also.
    I will check that too.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Re plugged the heater panel in but still the same. Worth a try though.
    Now have it in bits and low and behold I see a very tiny bit of solder on the track to do with the air direction selector.
    Warming up my iron now. Fingers crossed.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Power of the fans increased a bit the air flow direction is a tad knackered still.
    Looks like I'm looking for a replacement.
    Thanks for help though lads. As I said before it was worth a try.
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Dp again but only when I use the forum from the iPhone 3 gs. PC never gives me this trouble
  1. Non starter- ecu fried??
    By geordieric in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2012, 17:16
  2. HELP!!!!! Head Fried
    By BBMadness in forum General Motoring Chat
    Last Post: 7th May 2012, 23:07
  3. Ethernet adapter fried
    By bigmac in forum General Chat
    Last Post: 14th April 2011, 09:22
  4. Expensive Fried chicken
    By MLC in forum General Chat
    Last Post: 9th April 2006, 14:36
