Thread: Display
    Mar 2012
    Default Display
    Hi,
    New to the forum. I have just bought a 57 (2008) Plate Vectra C Exclusiv. I was wondering if i could change the display from the two line screen to one which will display the MPG, Range, etc. I know there are a few how 2 threads knocking about but the seem to be for a different model to mine as my car has the steering wheel controls and a BC button so i assume i don't require the new control stalk. Any advice would be greatly appreciated.
    Thanks.
    gwent
    You can do it as you car is full canbus but if you change the screen make sure that been despaired from the head unit or buy a new head unit and screen together plus you will need a sensor for the screen washer bottle and tech 2 to set it up
    hull
    Buy yourself a cd30 with paired screen from sri off fleabay or similar, straight swap if paired and bc functions (trip/fuel computer) will work, they did on mine.
    No tech 2 needed.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Right -
    you will need a full size display, without buttons on the bezel.
    Your vehicle is a full CAN set-up, therefore the stalk switches are not intended for use on your vehicle - only for half-CAN vehicles.
    Ideally therefore, you need to obtain either
    A complete head-unit and either a board info display (BID) or a Graphic info display (GID) which are paired..
    or get a display as listed above, but this must be divorced if fitted to match your head-unit.
    Once fitted, you may need to program the display (code index) to enable board computer functions.
    Not all displays have the BC enabled.
    Neither of my CD70 equipped vehicles did.
    Mar 2012
    Thats great guys. Really appreciate the information. Will try and get hold of the display and head unit from fleabay and give this a bash.
    hull
    I've had 2 screens and cd30's off ebay, both out of late sri's which have the bc enabled. Paid £80 first one, £50 tha latest one. Be patient they pop up from time to time .
  1. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  2. mp3 on display
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 27th August 2011, 14:54
  3. PS3 display
    By @ndy-e in forum Games Room
    Last Post: 27th December 2010, 08:21
  4. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
  5. LED DIsplay
    By dcraigen in forum Vectra C / Signum Car Chat
    Last Post: 18th September 2008, 10:16
