Thread: Cruise control turns off
    Regular Member big gra's Avatar
    Dec 2011
    southport
    Default Cruise control turns off
    Was cruising down the motorway on way to center parcs this week. Set the cruise at 70 after about 10mins turns itself off and spanner light come on, wouldent let me put cruise back on until spanner light went off, plus when got off motorway the car felt very very slugish, very little power. Its a 2.0dti. Any thoughts before i brave the trip home tomorrow.
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Spanner light will stop the cruise control and put the car in limp mode. Check all your hoses. One is likely to have a hole in it (if you find it just tape it up).
    Dec 2011
    southport
    Turned the car off and on again and then drove fine, will have to see what its like on the motorway on way home.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    The most common thing is the contacts in the cruise control stalk itself which if you remove the stalk and clean up the contacts normally
    Cures it but read the how to fella don't try and yank the stalk out
    Are you VXR Enough
    13 Post(s)
    Are you VXR Enough
    13 Post(s)
    Grrrrrrrr will we ever cure this double post crap
    Dec 2011
    southport
    would that problem put the spanner light on and make it go in limp mode?
    Wirral, UK
    Vehicle : Mokka
    Trim : SE - Orange Rock 's !!
    Engine : 1.7CDTi
    Well, as it's a DTi, there is a good chance it is something to do with the boost pressure or EGR.
    The first step is to check the black hoses that feed air into the inlet manifold.
    Getting the stored codes read would be usefull.
    Lots of posts on here about DTi problems, plus there is a few posts in the How 2 section too.
    Dec 2011
    southport
    Quote Originally Posted by TonyP2020 View Post
    think you might be right, ive done a bit of searching and seems to be similar symptons to people with egr problems. Will take it apart when i get home.
  1. Cruise control.
    By Hyperhart in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 20:02
  2. Cruise Control :(
    By paddyvectra in forum Electrical & ICE (including SatNav)
    Last Post: 11th October 2011, 01:26
  3. Cruise Control MPG
    By Phatty in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2008, 15:59
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control Help !
    By bennyk in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2007, 11:30
