Results 1 to 10 of 21
Thread: is it just me?
    Regular Member mrk's Avatar
    Vehicle : vectra hatchback
    Trim : improving
    Engine : 1.9cdti mas remap
    Year : 06
    Default is it just me?
    got a cd70 fitted last friday after ditching the cd30 with little display and found the bc works ok for fuel consumption.now i find i am constantly trying to improve the mpg, in nearly 2 years of owning the cdti i have never got over 38mpg,using the fill it up -wait till fuel light comes on and refill to the top and calc the fuel consumptionmethod.admittedly i am now driving less like a loon but i wonder when the bc god will let me drive a little more enthusiastically.
    sure i'm not the only one.
    final question what functions am i missing out on by not visiting the stealers to get stuff activated
    thanks mrk
    Depends what sort of driving you're doing mate - when I do motorway cruising I can get over 60mpg out of mine, but average about 50 with a mixture of urban and extra-urban...
    Trim : improving
    Year : 06
    i've got it above 42mpg over the last 80 mile so quite an improvement that is mostly 12 miles each way to work and back - no trafffic in the norning @5.30 usual rushhour on way home
    Sep 2010
    50mpg on A roads and through towns / villages,.. over 60mpg on motorways. (got 72 once on the way back from Wakefield!)
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    In standard setup a CD70 Navi with colour display will give you 3 main functions - Audio, Nav, BC
    If you have all the relevent modules, etc, it can be activated to permit Bluetooth and Aux In as well.
    Trim : improving
    Year : 06
    i was wondering what the main bc features were other than mpg as if i dont have them i dont know what can be activated
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by mrk View Post
    Once you select BC main and press the big dial, it enters the BC.
    Once in BC you should see you have BC1, BC2 and a timer/stopwatch function. Both BCs show the same MPG data.
    On mine I leave BC2 to show MPG data pretty much since I got the car, but BC1 I reset at each refuelling so it gives me data per tank.
    Only thing I've used the stopwatch function for so far was having a bash at working out the 0-60 time for my GSi.
    Jul 2009
    Yorkshire
    Quote Originally Posted by chewy71 View Post
    ...everywhere is downhill from Wakefield LOL
    Regular Member jimbo1987's Avatar
    Jan 2012
    southwest
    can i put this in a preface and what would work on it, or am i stuck with the tid cheers
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Quote Originally Posted by jimbo1987 View Post
    I think this goes back to the question of if your Vectra is Full or Half CanBus. CD70 requires a Full CanBus setup or a shedload of extra wiring in a Half CanBus vehicle.
    If you have six round buttons as remotes on your steering wheel you have Half Canbus.
    If you have two square buttons and a scroller on each side of the steering wheel, then you have a Full CanBus vehicle.
