Thread: power loss
    Plymouth
    Angry power loss
    Hi all
    Looking for solutions to my problem!!
    Jumped in the car today, car started fine, pulled away and drove off down the road. No warning lights on but when I put my foot down in 2nd gear nothing happened - just flat like it was in limp mode. there is just no power there at all!!! Any possible solutions welcomed????
    no fault codes appear on diagnostics...........
    Vectra is a 2.2 SRi Direct 2006 on 62k miles
    If you have lost power in a specific gear, then it is most likely a gearbox issue or it has not engaged
    Plymouth
    I get the same response throughout the gears. It is very sluggish then gradually picks up but does not reach full power
    Plymouth
    it appears the timing chain is slack and the tensioner is shot away. Now to check if any further damage has been done to valves!
    Whats the point in putting a chain instead of a belt, when the tensioner can fail and do th same damage!!! Funnily enough the replacement tensioner is a modified version!!!!! Shouldnt this be a recall????
    Full Member dezzyb66's Avatar
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Engine : 1.9cdti 120
    Eek Pipes
    All so check your vacum pipes thats a favourite for loss of power
    Plymouth
    Will do cheers
    Aug 2011
    carlisle
    Vehicle : Vectra c
    Thumbs up Pipes
    No worries
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. loss of power
    By STRETCH2009. in forum Engine & Drivetrain
    Last Post: 8th August 2012, 18:44
  3. Power loss HELP
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 28th July 2012, 12:34
  4. 2L DTI '53 Loss of Power
    By BigTunz in forum Engine & Drivetrain
    Last Post: 3rd November 2011, 17:27
  5. loss of power
    By philly in forum Engine & Drivetrain
    Last Post: 11th May 2009, 07:21
