Thread: 1.9cdti 150bhp starting issue
    Aug 2010
    south northamptonshire
    Default 1.9cdti 150bhp starting issue
    hi guys
    on my vectra 1.9cdti 150bhp it has just started struggling to start on first turn over. you crank it over first time and the starter just spins asin lack of fuel, so i turn off the ignition turn it back on crank it again and it fires straight away has anyone else had this issue im gonna start by changing the fuel filter but im wondering if it could be loosing fuel pressure when not running therefore having to prime fuel through to enable it to start what you guys recon?
    many thanks adam
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Is it just when cold? Or warm? or both?
    Aug 2010
    both mate already replaced the glowplugs :/
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    When you turn on the ignition (but not operate the starter), can you hear the HP fuel pump (behind you) spinning up?
    Sounds like lack of fuel if just turning over but not starting, both hot and cold.
    Also check the EGR and clean it. I'm sure I've heard that a sticking open EGR can cause starting issues (may be wrong though)
    Aug 2010
    i just checked it i couldnt hear the hp pump but the radio ****** turn't on so will re-check that in the morning as for the ****** egr valve i hope it ent fooked again i only replaced it a year ago lol. i will keep checking bits and bobs cheers for your help mate.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by bridge_eee View Post
    No probs mate.
    You should hear the pump quietly behind you for a few seconds when the ignition is first turned on
    HTH
  1. I have got a very serious issue. 150bhp engine.
    By 123rado in forum Engine & Drivetrain
    Last Post: 8th September 2012, 18:47
  2. does your turbo on vec 1.9cdti 150bhp
    By bridge_eee in forum Engine & Drivetrain
    Last Post: 25th September 2010, 20:13
  3. Loss of power issue (1.9CDTi SRi 150BHP, Vectra C)
    By Big Sie in forum Engine & Drivetrain
    Last Post: 20th April 2010, 17:46
  4. Help Please. Vectra 1.9cdti 150bhp
    By collieq in forum Engine & Drivetrain
    Last Post: 1st January 2010, 13:05
  5. 05 1.9cdti 150bhp sri down to £7.5k
    By m20_swe in forum Cars for sale
    Last Post: 7th February 2008, 23:54
