Results 1 to 3 of 3
Thread: Amp help needed
    New Member minimission83's Avatar
    Sep 2011
    hartlepool
    confused Amp help needed
    hi all have started modding the sound system in my vectra c estate with more trouble than it was worth really, have replaced all the door speakers with vibe slick customs 6.5" and have also built a boot in stall with the vibe slick 6x9" will also be housing 2 10" vibe subs when they become available at my dealer, problem i need help with today is what amp or amps do i need to run the 6 speakers ?
    Regular Member Tinks's Avatar
    Jan 2012
    Whittlesey
    Vehicle : Vectra C Elegance
    Engine : 1800
    Mileage : Lots
    Evening, I would either do 1 of 2 things.
    1: if space is an issue then a single, mid power Rockford Fosgate with passive filters - the more you load it the more power you get!!
    2: Good quality 4 channel amp with high pass filters and good quality high power bridgeable 2 channel or monoblock with low pass filter.
    Dont buy cheap and cheerful amps as this will ruin the sound quality of a decent head unit and decent speakers.
    Also I would get decent quality power and signal cabling - system only as good as the weakest link.
    HTH
    Tony
    Jan 2012
    Whittlesey
    Engine : 1800
    Mileage : Lots
    HTH
    Tony
  1. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  2. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  3. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  4. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
