Results 1 to 10 of 28
Thread: Thermostat Issue??
    Regular Member KeeronMac's Avatar
    Mar 2011
    Donegal
    Question Thermostat Issue??
    Hi guys, not sure if this is where I should post this question but here goes.
    I have noticed that my temp gauge barely moves, I did a quick search and seem to have all the symptoms of a dodgy thermostat i.e temp needle doesn't move, takes ages for heater to blow warm air etc.
    I took it to a garage and told him what I thought was the problem. He plugged in the computer and says that the sensor is working fine and that it is the actual gauge in the dash that needs replaced, although he said this was more hassle than needed as everything else was working fine. I'm not so sure though.
    He then said that it could be caused by the EGR, and strangely enough the spanner light wont turn off now??
    I'm going to clean the EGR myself, should I get the thermostat anyway??
    If so are the ones of ebay ok to get??
    Was looking at this:
    http://www.ebay.co.uk/itm/Vauxhall-V...item35b9f1151b
    Would that be ok?? Also need new brake discs and was wondering would these be ok?? I ask because they seem to be a very reasonable price, almost to reasonable
    http://www.ebay.co.uk/itm/VECTRA-C-1...item3f148115ad
    Car is an 05 reg Vectra, 1.9 CDTI
    PRESTON
    Reading the listings,both those items on Ebay should be right for your car. Re the spanner light, did the garage say what the codes were that wont clear, that would help identify if the EGR is at fault.
    Personally i would replace the thermostat, they are prone to failing and ages to warm up and gauge issues are the main symptoms. Little bit of a pig to do, so allow a couple of hours.
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Same symptoms as mine for the thermostat, I replaced it as chances are it was that and no the guage, Job was fixed, Now takes 5 - 7 miles to warm up of normal driving, get warm air within about 1 mile usually.
    Regular Member GCM's Avatar
    May 2007
    Coventry
    Hi, I had the same engine temperature issues as you and brought the thermostat from the same seller last week and a genuine Vauxhall part was supplied. Fitted it easily in a couple of hours on Friday afternoon following the how 2 posted on here and all is ok now.
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Quote Originally Posted by KeeronMac View Post
    If yours is the 150bhp, just follow the how to - if its the 120.............. prepare for a nightmare - the EGR cooler bracket covers the lower bolt on the stat housing
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Its the thermostat not the temperture sensor that has failed. The temperture sender will be working fine. Seems the man in the garage didn't know what he was talking about and could have eneded up costing you a load of dosh for no reason!
    Mind you if would be more costly for you for the garage to replace the dash gauge than to replace the thermostat and therefore a fast buck could be made by pretending to change the dash and instead doing the thermostat (or am I being a bit cynical)
    Regular Member mcpitman's Avatar
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    99% sure it's the stat. Thought my temp gauge was knackered qnd changed the complete stat and housing and all sorted.
    Tis a b***h on the 120.
    May 2011
    Derby
    Trim : Club
    Engine : 1.9 CDTi
    DP bug
    Mar 2011
    Donegal
    Quote Originally Posted by barney490 View Post
    He never mentioned what codes came up, never even thought to ask to be honest, I find it strange how the spanner light is up now after he said the EGR could be a suspect. The engine symbol under the fuel gauge is gone only to be replaced by the spanner...
    Quote Originally Posted by Chris B View Post
    It is the 120bhp I remember my friends dti was right at the front and easy enough to remove, yeah mine might be a bit more work...
    Quote Originally Posted by merikiito View Post
    You see thats what I thought, I was thinking that the thermostat wouldn't be that expensive, probably not too awkward a job either, hence he said the dash, but if it was the dash surely the needle wouldnt move at all (it moves slightly if i put the foot down but drops straight away after), that made me doubt him slightly. Having said that he said not to bother changing the dash.
    He seemed genuine enough though, said it would be no problem if I wanted to source my own parts and he would fit them, rather have a go at it myself first.
    Mar 2011
    Donegal
    Quote Originally Posted by mcpitman View Post
    Yeah I think I'll get the stat, hopefully that sorts it, car running fine bar that
    And is anything simple on the 120's???
  1. new thermostat
    By wildchild in forum Vectra C / Signum Troubleshooting
    Last Post: 24th August 2012, 14:02
  2. Can anyone tell me what a thermostat does?
    By twinxster in forum Vectra C / Signum Car Chat
    Last Post: 3rd February 2012, 22:03
  3. Thermostat Issue?? Or Something Else
    By Elahi_786 in forum Engine & Drivetrain
    Last Post: 18th January 2012, 22:58
  4. Thermostat issue?
    By justin32 in forum Engine & Drivetrain
    Last Post: 21st October 2011, 19:14
  5. Thermostat
    By shrekster in forum Engine & Drivetrain
    Last Post: 26th January 2009, 01:40
