Results 1 to 3 of 3
Thread: Window not working
    Dec 2011
    LANARK
    Default Window not working
    Hello guys wondering if u can help me my back driver side window not working does any of yous no how I can check it to c what is wrong it does not work with the front controls or rear ones I have vectra elite saloon
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Probably a fuse in the rear fuse box in the boot.. look in your owners manual to see which one it is.
    or a broken wire where the rubber tube that links the door to the frame flexes every time you open and close the door.
    If it was just one window switch, then I would say that the switch contacts are dirty - a common fault on the Vectra-C
    Finally, check the connector to the window regulator motor itself to see if it has become detatched.
    Dec 2011
    LANARK
    Cheers pal will do tell u how I get on
  1. window switches aren't working
    By Darryl2.2DTI in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2013, 16:06
  2. window washers not working and
    By wiganrl in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2011, 23:48
  3. window washer jets not working
    By steve-wolves in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 13:43
  4. window washer not working
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2009, 15:29
  5. Electric Window not working!!!!
    By Stevie-B in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2007, 13:17
