Results 1 to 10 of 17
Thread: How cold is your air con?
    Dec 2011
    Seaham
    Default How cold is your air con?
    I am wondering if mine needs re-gassing? I bought the car in December and havent really had any need to use the air con yet.
    Last week when it was warmer I turned it on, turned the heater control right down, but did not think the air coming out was chilled or colder then the outside temperature?
    IN my previous cars, you can feel a "chilly" blast.
    Any thoughts? Outside temperature was about 15-16 degrees.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    It probably just needs a re-gas. Can make a huge difference
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    as tony says.mine gets so cold it numbs
    Regular Member james chambers's Avatar
    Sunny Leicestershire
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    Mines good aswell, as I recharged mine last week
    Previously owner was probably only using the air con occasionaly
    The trick is to either use it all the time or at least 50% of journeys
    Equally, the Pollen Filter may be saturated
    That was what happened to mine, easy enough to replace
    Trim : SRI
    Engine : Y22SE
    Mileage : 100,000
    If you don't use your A/C very often during the winter months, run it up for at least 5 minutes a week. That will lube the seal and stir the gases around the system
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Air con should be left on all year round, rarely will it go wrong and frequent re-charges will become a thing of the past. Never had a fault with aircon in a Vectra by applying that very principal simply because the unit is working constantly (apart from really cold weather when I believe the system will regulate its operation).
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    Ice cold but never turn it off.
    Nov 2007
    Kent
    I used to keep a pair of brass monkeys in mine but they escaped last week now they keep banging on my door asking for their balls back? They can't have them.
    11 Post(s)
    Quote Originally Posted by james chambers View Post
    Like a dog, AC isn't just for Christmas. It's for all year round. Makes and excellent demister too if used in conjunction with the heater.
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. So you think it is cold here.
    By ed taylor in forum General Chat
    Last Post: 23rd December 2009, 15:36
  4. No Cold Air
    By dhwigston in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2009, 18:52
  5. A cold one.
    By shan in forum General Chat
    Last Post: 10th September 2007, 00:40
