Thread: Rev counter not working
    Mar 2012
    london
    Default Rev counter not working
    HI Guys
    Ive recently bought a 2005 vectra cdti sri. Its a beautiful car and drives perfectly, but today i noticed the revs on the dash dial didn't match what the engine was actually doing.
    Basically, they sit at around 500 and then when the turbo kicks in the counter jumps into the red. Its got me totally confused and worried this might be a serious problem.
    The rest of the dash works fine and no warning lights are on. All controls/ speedo are perfect. Only the rev counter is wrong.
    Has anyone here ever seen this before?
    Dec 2011
    Seaham
    Think you need to find where the rev counter takes it pick up off? Possibly a crank or cam sensor? Check the connectors for corrosion, squirt some WD40 into them and work them in and out a few times.
    Regular Member MrDerv's Avatar
    Nov 2011
    North East (Beamish)
    If it was Cam sensor or Crank, you'd have a spanner light thrown up on the dash, and possibly running issues too.
    I'd see if you can remove the dash cluster and check the plug connection to make sure it's sitting securely.
    Failing that, you may have a duff dash
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Could it not be the CIM?
    Regular Member gibbon7000's Avatar
    lincs
    Quote Originally Posted by tony-1977 View Post
    I was just thinking the same
    Mar 2012
    london
    Ok... and whats that?
    I'm no good with cars -at all. I have no idea how to go about removing the dash. Is there any guides/instructions and how difficult is it?
    Thanks for all the replies btw
    lincs
    The cim is like an ECU for all the dash electrics (maybe more) I think i'm right in saying they have to be programmed to the car with tech2. I do believe the cost is about £400-£500 all in.
    11 Post(s)
    Quote Originally Posted by Ben50n View Post
    Think you need to find where the rev counter takes it pick up off? Possibly a crank or cam sensor? .
    The alternator, IIRC, on diesels.
    Nov 2011
    Nope, Crank sensor
    11 Post(s)
    Some diesels use the alternator for the rev counter signal though.
    [ame="http://en.wikipedia.org/wiki/Tachometer"]Tachometer - Wikipedia, the free encyclopedia[/ame]
    "In older vehicles, the tachometer is driven by the RMS voltage waves from the low tension (LT) side of the ignition coil, while on others (and nearly all diesel engines, which have no ignition system) engine speed is determined by the frequency from the alternator tachometer output. "
  1. rev counter display
    By chris1804 in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd February 2012, 19:07
  2. Speedo and rev counter stopped working ??
    By Knuckle in forum Vectra C / Signum Troubleshooting
    Last Post: 11th June 2011, 16:59
  3. Speedo & Rev counter not working on vauxhall vectra cdx 1999 modelv
    By fredweb in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 00:14
  4. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  5. Ciggies To Go Under The Counter
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 25th March 2008, 09:13
astra h rev counter not working
08 vectra rev counter not working
vauxhall astra rev counter not working
corsa c rev counter not working
vectra rev counter jumping
rev counter not working vauxhall corsavauxhall vectra c rpm meter 0 astra rev counter not workingrev counter not working opel corsa drev counter on astra not workingrev counter astra hcorsa d rev counter not workingopel vectra b rev counter doesnt showzafira diesel rev counter not workingzafira rev counter not workinghow does a factory tachometer work in astra vauxhalldiesel car rev counter not workingfree blonde milf pornastra h rev counter connect in engine bayvauxhall astra diesel rev counter not workingvectra diesel 2005 rev counter not workingvectra c rev countervxr rev countervauxhall zafira rev counter not workingastra j rev counter not working
