Results 1 to 10 of 15
Thread: Can someone try and point me in the right direction?
    Mar 2011
    South Normanton, Debryshire
    Default Can someone try and point me in the right direction?
    Hi,
    Ive just driven to work and noticed that the handbrake light stays on i turned the car off and tried again but a few seconds later it was back on with the hand brake being fully on.
    I've just read on here that its also a warning light for low brake/clutch fluid now can anyone point me in the right direction of how to check this as i know where nothing is in my car or if there a how to on here so i can at least go and have a quick look on my break to see if it could be one of them problems.
    What esle could it be if its none of the above mentioned?
    Cheers Alan.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    The brake fluid reservoir should be over the left hand side ( when looking from the front) at the rear of the engine bay.
    Should have max an min marks to help see where fluid level is.
    How ever if it is below minimum, Questions need to be asked why?!
    Pads worn down, fluid leak etc
    how long have you owned your vec and you don't know where anything is? Do you not perform basic weekly checks?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Mar 2011
    Quote Originally Posted by Critch View Post
    Thanks for this ive owned my Vectra for a year now and NO i dont know where anything is or do basic weekly checks never have never will but how can i do weekly checks in the first place if i dont know one single thing im looking at under the bonnet?? im sure im not the only person on here that doesnt know where things are on there car.
    Hi AlanK and welcome to the site. One way of getting used to doing the weekly checks Is that every thing that needs looking at is coloured yellow or yellow and black. Oil filler cap. Dipstick for checking oil level. Brake and clutch fluid cap (combined reservoir). coolant reservoir cap.
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Alank View Post
    So you never will? But you want help once you've got a fault?
    All I'm trying to point out is that weekly checks are vital.
    I'll put it too you like this.
    On a weekly check you could spit oil has dropped slightly so get it investigated. To find a small leak some where. Cost say £50 for a garage to investigate.
    Or in your case you don't check so have no idea you have no oil first thing you no is when your cars thrown its piston down the road. Cost over 2k
    It takes 21 days to create a habit. But if you can get into habit of opening the bonnet once a week checking all your levels, check tyre pressures etc.
    Trust me you will catch any faults early and save a whole heap of cash in the long run.
    But for help in this situation I believe theirs a page in the owners manual to help
    Mar 2011
    im not saying im not greatful for your help but if i dont know what im looking at in the first place then i wont be doing a weekly check which in the long run again would just be a waste of time as i wont know if thats a problem or not if this is making any sense. I do check oil levels and tyre presures etc im not that bad but was just saying today is something completely new to me being a very very very big novice to how cars work even through ive been driving for 8years.
    11 Post(s)
    Open the glovebox and see if there is a thing in there called a handbook.
    If there is, then read it from cover to cover (paying particular attention to the maintenance section) as it contains all the info you need.
    If you haven't got one, then those kind people at Vauxhall have one available for download from their website.
    http://www.vauxhall.co.uk/manuals.html
    It might not the correct year for your car, but the info contained within will be enough for what you need.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    First thing is the switch in handbrake itself not jammed? Reason being you have a pre faclift and I would say that if there is a fault with the braking system it will put the 'handbrake' symbol up in the screen in the rev counter. Facelifts would use the handbrake light I would imagine as they don't have the screen in the rev counter. However as it is your brakes check brake fluid and pad levels though.
    Full Member gibbon7000's Avatar
    lincs
    Give Alank a break. We all come on here wanting advice about one thing or another. I know loads of people who do not do weekly checks on the vital fluids etc. So what? Doesn't mean we shouldn't help or make the guy feel like he's useless for not doing so.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
  1. Replies: 4
    Last Post: 3rd July 2012, 20:04
  2. Anyone point me in right direction?
    By srinav in forum Vectra C / Signum Car Chat
    Last Post: 10th August 2011, 17:12
  3. Can some one point me in the direction for how 2 vxr diffuser rear
    By philgst in forum Vectra C / Signum Car Chat
    Last Post: 27th July 2011, 23:30
  4. point me in the right direction
    By webby2k in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2010, 16:46
  5. point me in the right direction???
    By big rich in forum Detailing and Car Care Discussion
    Last Post: 14th January 2009, 01:55
