Results 1 to 10 of 13
Thread: air con-climate?
    fife
    Default air con-climate?
    Hi guys i gave a 1.9cdti(8v) 04 platewith air con, that doesn't work due to a faulty clutch unit in the compressor, i have recentlly bought a 1.9cdti(16v) elite estate 54plate, Both preface lift
    The estate has full climate control and was wondering if it's possible to swap this over whilst i swap the compressor it also has scroll buttons on the steering wheel where mine has push buttons i'd always assumed that buttons = half canbus scroll = full canbus but after reading some threads on here it appears not is this the case?
    All or any info would be apprecaited
    Thanks for reading
    fife
    Anyone Please
    just need to know if there is any other way of finding out if full or half can?
    The Estate will be full canbus mate. The climate control will not be swappable - it consists of a million more components than the bog standard air con system including cabin temp sensors, extra valves and ECU stuff. The pump itself may be the same (you'd have to check the part numbers) but the rest of it is a complete non-starter.
    Much like the car.
    fife
    Thanks for that but would it not be possible if i swap everything over inc heater box and wiring looms?
    I suppose technically anything's possible - if you have a few weeks on your hands to do it there's no harm in trying...
    Be sure to do a full report with photos though...
    Feb 2011
    Selby
    The change from half-canbus to full-canbus took place from a manufacture date of August 2004. So an 04 plate was probably made before August and so half-canbus, and a 54 plate is more likely to have been made after -though there are some 54s with half-canbus that were made before August, but not registered until after.
    fife
    cheers guys can all the ecu's be cleared with tech2 and then progammed to my car i was planning in swapping the loom over due to the estate having all the wiring for heated seats and mine doesn't and i have fitted leather and switches so just want them to work, I know it will be a big job but had to replace the engine and heater matrix when i first got the car so not donted by that, just don't know if my REC would be able to be programmed to work all the seats, climate rear elec windows and rain sensor
    fife
    Hi Guys hope some one on here can HELP!!!!!!!!!!
    well i have started today and took the dash out. fitted the new dash support with wiring loom plugged in the new parts climate, cd40 and new screen and activated it in the CIM BUT!!!
    engine now not starting No communication with any other ecu(bcm rec uec cdi abs ETC) refitted original dash loom and car starts suspect can wiring not the same
    So my NEEDS are
    1 can any one supply me with wiring diagrams for my cars dash harness and a face lift dash harness so i can compare the connectors at both ends or is just to do with half/full can bus?????????????????
    Wondering lonely as a cloud
    24 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Half and full can looms cannot be mixed mate the reason being you don't have the necessary interconnections and rather than trying to rewire the loom you would be better buying a loom that is for the year of car with the functions on it you want it would take hours and hours to sort it and it just isn't worth it, it was enough of a nightmare on my preface full can going to a facelift loom the variations even in the radio plugs mean best get the right or a close doner loom.
    With all the other things you are planning rear electric windows and heated seats (wiring behind switches missing) may mean you need a body loom as well or several wires adding having just done all the work you are planning with Dean on a couple of cars it is a shed load of work but it is doable
    fife
    i have the loom from the donor car but it was an estate but will this then cause other issues with the rest of the car?
    Can any one tell me what is meant by half can bus and full can bus as i am aware there is a can high and can low but cant get my head round half can
  1. Climate into non climate question
    By SlowCoach in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2012, 11:58
  2. aircon to climate
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 02:30
  3. another climate control
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 19:43
  4. Climate Control
    By shark and mel in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 18:33
  5. Climate Control - Yes You Can Help!!!
    By mushy2007 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 00:15
