Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: CDC70 Navi worth it?
    New Member erni3wi5e's Avatar
    Feb 2012
    Ipswich
    Default CDC70 Navi worth it?
    Been looking for a satnav for the Vec. Was wondering if people would advise an aftermarket radio or a OEM one? Can you fit and AUX in to the cdc70?
    Any help would be great.
    scottish region
    You can fit aux to cd 70 yes I prefer the oem look so I will stick with cd70 navi
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Only the much later build CD70 Navi headunits have Aux In either fitted or directly 'fitable'.... however, there is a chap somewhere who can retrofit the Aux In hardware for you. As long as the firmware is post Jul 2010 it has support for Aux In.
    Feb 2012
    Ipswich
    Is it a good quality Satnav though? or just average?
    Regular Member david-bell's Avatar
    eastlothian scotland
    Vehicle : vectra vxr
    Trim : vxr
    Engine : 2.8 v6 turbo
    Mileage : 31000
    I recently upgraded mines to full colour cd70navi and have to say can't fault it I also like the om look and sat nav gets us to we're we need to go hth
    Regular Member BYGino's Avatar
    Jun 2011
    Lanarkshire, Scotland
    The sat-nav is average tbh.
    If you get up to date discs you loose things like TMS but if you want TMS you have to use 6 Year old map discs and then you loose postcode entry (IIRC)
    I use it and it's OK. Best thing is it will redirect you to a petrol station when you get low on fuel - which is handy in a 2.8!
    Personally, I've found that some of the routes it takes are a bit strange - i.e. roads i know to be much quicker my way as opposed to the way the sat-nav sends me. it's nicely integrated though and I wouldn't swap it for an aftermarket model but since you're changing anyway, it's a tough call. Note that I did do a full tour of the scottish highlands with it and it got me round but it got a bit confused on SKye and sent me down a looong, winding, hilly, single track road instead of the much easier dual carriageway!
    Basically, if you want an OK system nicely integrated, go for it. If you're not bothered about integration - get an aftermarket unit.
    Jun 2011
    DP-
    11 Post(s)
    CDC70?
    What one of them?
    Or do you mean the CD70?
    Anyway, apart from not being able to enter a full post code, it's fine IMHO.
    And the stereo part of it, you can play MP3s once you've burnt them to CDR or CDRW discs.
    11 Post(s)
    Quote Originally Posted by BYGino View Post
    If you get up to date discs you loose things like TMS but if you want TMS you have to use 6 Year old map discs and then you loose postcode entry (IIRC).
    Both my previous 2005 and current 2010 map CDs allow postcode entry (well the first 5 digits anway)
    Granted though, the newer discs that uses traffic master instead of TMS is poor.
    Feb 2012
    Ipswich
    CDC70?
    What one of them?
    My typing fingers are crap.. (so is my vauxhall knowledge... at the moment n e ways)
    Hmm not sure atm plus the wife has my purse strings tight.
  1. Cd navi 70
    By andyco11 in forum Electrical & ICE (including SatNav)
    Last Post: 17th May 2012, 15:15
  2. Cd 70 navi
    By dav3-w in forum Electrical & ICE (including SatNav)
    Last Post: 15th October 2010, 01:53
  3. Wanted - cdc70 nav or cd70 nav
    By L11Marc in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2010, 16:17
