Results 1 to 10 of 15
Thread: park pilot location plug help
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    Default park pilot location plug help
    need to disconnect fron wiring plug as my sensors are temp removed to make rear ones work.....but where are they plugged in
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The front multiplug, just next to the temperatur sensor, at the center of the front bumper.
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    on my signum its under the trim between the n/s rear light and the lock catch i think..
    Jun 2009
    bradford
    thanks guys, but neither will work with font sensors unplugged, so i was thinking if I unplug the fronts at source(where they come from the body) if that makes sense then my rears will work until i get my fixings for the front bumper.....in other words which is the cable that controls front and is it plugged into rear box in boot?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    ooops i think you may have meant front sensors.. in which case ignore my post as thats where the rears plug in.. my fronts are wired back to the rec, but have a connection behind the front bumper
    Jun 2009
    bradford
    Quote Originally Posted by Caveman_nige View Post
    right........so in the rec....which is the plug mate? any idea?
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    the park pilot module plugs in to the rec and the harness connects to that.. its been a year since i had that apart so cannot recall exactly what it looks like.. from the module the front harness then goes through the car out by the rad where the front bumper parking pilot harness plugs into it..
    Jun 2009
    bradford
    cheers mate will have a look in the morn
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    when you look at the park pilot module its the top black plug that operates
    the front parking sensors but doing this will de activate the rear sensors,
    rear speaker and the can bus connections as these are in the same plug as
    the front parking sensor wires.
    your best just un plugging the front bumper harness to disconnect the front
    parking sensors.
    Jun 2009
    bradford
    Quote Originally Posted by andy.l View Post
    parking sensors.
    cheers andy thats what I had to do.....vx cant get fixings for 8 days, but because its disconnected at the front - the rear ones no longer work either.......just want a temp solution as rear ones are relied on heavily...lol
    thought they were seperate to each other as most peeps just have rears
  1. Park Pilot
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 22:39
  2. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  3. Park Pilot
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 9th December 2009, 20:26
  4. Park pilot
    By bigmac in forum Electrical & ICE (including SatNav)
    Last Post: 25th July 2009, 20:42
