Results 1 to 10 of 24
Thread: Rear disc removal nightmare
    Jan 2010
    Scotland
    Default Rear disc removal nightmare
    Evening guys.
    Need to replace pads and discs but ive rounded the torx bolt on the caliper carrier due to using a normal socket.
    Whats the chances of grinding the head off and removing that way as i need to replace the bolts anyway???
    cheers
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Best bet is to hammer a smaller socket over them or use a locking nut removal tool, the last thing I would want to do is cut the heads off.
    Full Member Big Sig's Avatar
    Stilsons or pipe grips may help
    scotland
    mole grips and HEAT .
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by gsxrster View Post
    Must admit, having welding gear to hand does help.
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    irwin
    http://www.ebay.co.uk/itm/IRWIN-5PC-...item2a16082f1a
    or halfords (and others) do a roller stud removal type which works. These bolts are torqued to 130+ Nm and not at a great angle or access so consider if you cannot get good access taking to a garage and get it on a two post stand. A garage can always weld a nut on whats left of the stud.
    As rushy said leave something to get hold of.
    Jan 2010
    Scotland
    Thought about the smaller socket but they are mega tight and have loctite on the threads, dont think it will work but suppose id be better trying that first.
    cheers
    Regular Member Dane-10's Avatar
    Feb 2012
    Sheffield
    Did mine today, was all tight! Though i went and got a E20 Torx socket Worth the money to get one,
    Failing that, I would be at the now with some heat, and smashing a smaller socket on there.
    Jan 2010
    Scotland
    Quote Originally Posted by Dane-10 View Post
    did you use an extension bar or a normal ratchet.
    .i rounded 1 so i'll nip out on monday and get the correct torx
    cheers
    Dec 2011
    Northumberland
    Sorry I missed the original point about you not using the correct socket. Most motor factors have a set for £15 quid (sealey) Halfrauds do a professional (GFL) for appx £22. False economy not buying the right tools. Use with torque bar and get replacement bolts ordered.
  1. 4 disc changer , cartridge removal ?
    By biffbangpow in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2013, 01:30
  2. rear disc removal
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2012, 20:19
  3. Nightmare trying to remove the rear caliper carrier bolts!!
    By richiem in forum Suspension, Wheels & Brakes
    Last Post: 4th February 2011, 01:10
  4. Rear lights nightmare
    By Nav-Man in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2010, 07:54
  5. Rear Disc Dust Shield Removal...
    By Leemarksmith in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2010, 15:36
renault scenic rear torx socket
renault rear e20 socket
rear bolt caliper renault scenic torx
