Results 1 to 10 of 15
Thread: blower speed 4 not working. 1,2,3 OK
    Mar 2012
    plymouth
    Default blower speed 4 not working. 1,2,3 OK
    Sorry if this is wrong section, not sure if blower problem or electrical (also blower section says private and I cannot access). I can use blower speed 1, 2 and 3 so not resisitor fault. Nothing from speed 4. Also demister button does not operate speed 4. I have a 2003 1.8LS. Thanks for any help.
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Do a search for resistor pack its one of the most common failures and is cheap to sort.
    South east
    Except that the symptoms he's described are the complete opposite - usually it's nothing on speeds 1-3 and only 4 working. He says his 4 doesn't work and 1-3 do.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Sounds like the by-pass relay to me.
    The relay operates on speed 4 and by-passes the resistor pack. It is located above the glovebox. Remove the glovebox and look above it. I think there are 2. Try swapping them round and if the blower ONLY works on 4 then you have solved the mystery.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    It's the resistor that's how mine was 2-3-4 worked but 1 didn't !!
    Nov 2007
    Stourbridge
    ive got the same problem too 1 and 2 and 3 work fine but 4 and front demister switch dont work is it defo the thermal resistor again ?? last time only 4 worked any update would be gratefull
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    as already been said, that if blower works on 1,2&3 but not 4 its will most problery be the brown relay behind the glove box.
    Nov 2007
    Stourbridge
    brown relay or brown fuse?
    Jul 2010
    This is London baby
    Trim : SXT
    Year : 2010
    Mileage : 53000
    The brown relay behind the glove box, this controls speed 4.
    just noticed on other post put fuse when its a relay doh.
  1. FAN BLOWER NOT working at all....
    By Radek996 in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2011, 16:52
  2. heater blower only works on 4 speed
    By hippo in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 9th February 2010, 14:38
  3. blower speed
    By jamie226 in forum Electrical & ICE (including SatNav)
    Last Post: 12th September 2009, 21:33
  4. blower only working on number 4
    By damadom in forum Electrical & ICE (including SatNav)
    Last Post: 30th January 2009, 17:28
  5. Blower not working correctly
    By djr69uk in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2008, 16:22
