Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: My DPF is knackered! Help!
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Default My DPF is knackered! Help!
    Well i got the fault codes on the car read after it had been stuck in limp mode for a while. Turns out its the DPF thats causing me problems, its total blocked up. Also the glow plugs are showing a fault, the car starts fine tho.
    The garage guy suggested jet washing out the DPF pipe to clear it out a bit, but this might only give me a few months out of it.
    I got a quote from MAS performance to blank and map out the EGR, remove the DPF and get a remap with a rolling road session all for £350 so that seems reasonable but i will have to save up and maybe wait till next month.
    Whats the best short term fix guys? I hear some people knock out th internals but when i mentioned it to the mechanic who read the codes he thought that doing that was a bad idea?
    scottish region
    Does the vectra not have the dpf light on dash warning you
    Nov 2011
    Akrotiri, Cyprus
    Is there a seperate light for the DPF? I just have the normal fault light, the car with spanner.
    scottish region
    Well on the zafira the glow plug light flashes when the dpf is 50% blocked or last generation was interupted but I do all motorway miles so I've never seen the light on except the day I collected car from dealers
    Nov 2011
    Akrotiri, Cyprus
    Ah, my glow plug light is doing that! But it has only started doing it since this morning when it was hooked up to diagnostics at the garage. Think the bloke tried to clear the fault codes but they are back lol!
    I work in kent mon to fri so i do plenty motorway miles too.
    scottish region
    Now its flashing take it a blast above 2000rpm
    Regular Member Chuff's Avatar
    Sep 2011
    Oxfordshire for Pleasure, Berkshire for business
    we had a car in with a blocked DPF this week. all the usual tricks failed to unblock it
    the owner let us trial a DPF unblocker, from wurth i think
    after a few attempts at regeneratiing, a LOT of smoke and soot and all is good and DPF unblocked
    Nov 2011
    Akrotiri, Cyprus
    Just been out for lunch and had the car warmed up and drove about 30 miles, its still on. And in limp mode
    I might go out again tho and give it a blast in 4th gear or something to keep the revs a bit higher and see if it regens.
    Stupid idea having the blasted thing invented in the first place lol
    scottish region
    Lol as above try a dpf cleaner and a run
    Nov 2011
    Akrotiri, Cyprus
    Quote Originally Posted by Chuff View Post
    Is that one of those aerosol things you spray in the intake?
    Anythings worth a try if it might work! Is there a link to it?
  1. ECU is knackered
    By dhwigston in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 16:09
  2. Think my key is knackered
    By vectrasri20t in forum Bodywork & Interior
    Last Post: 26th February 2010, 12:01
  3. Im knackered.....
    By PAULMAC77 in forum General Chat
    Last Post: 14th April 2009, 09:51
  4. I'm Knackered
    By AJA in forum Comedy & Humour
    Last Post: 13th February 2006, 10:45
car dpf cyprus
is my dpf knackered
