Thread: Help! Where do I blank egr??
    Jun 2011
    South Wales
    Default Help! Where do I blank egr??
    Just a quick one.... I have received my egr blanking plate through the post today, where is the best place to fit it? ( in the garage is not the answer I'm after!) does it go in front or below the egr itself? It's a 1.9 cdti 120 also, its booked into be remapped on Monday, am I better doing it now or after the remap?
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    if your deleting the egr with the map then you may as well wait. i think it goes under the egr but im not sure
    Regular Member Chris B's Avatar
    Jan 2012
    Essex
    Does this help?
    Part #1 being the blank / partial blank
    Regular Member N3LTY's Avatar
    Jan 2008
    Crewe
    Trim : SRI
    Engine : 1.9CDTI
    I thought the blanking plate went on the bottom not the side!
    Regular Member northpole's Avatar
    Apr 2016
    Ipswich
    15 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    it doesn't matter where you put it as long as it is connected to either side of that pipe.... i would put it on the beginning just because it is closer to the hole on the exhaust manifold, meaning the gasses are blocked earlier, this in turn stops it from having a weird bounce back effect in the flow of the manifold... but due to the gasses flowing quite hard in there it shouldn't cause a problem.
  1. 2.2 dti egr blank
    By Al 22 dti in forum Engine & Drivetrain
    Last Post: 2nd March 2012, 00:50
  2. Where can I get an EGR blank for a 2.2 Vec C?
    By Partyvan in forum Petrol Engine related
    Last Post: 5th January 2011, 21:52
  3. blank dvd
    By pyro_maniac in forum Games Room
    Last Post: 1st January 2009, 22:17
  4. blank egr off ?
    By peadar in forum Diesel Engine related
    Last Post: 27th October 2008, 23:01
  5. Map gone blank
    By Paul_O in forum Electrical & ICE (including SatNav)
    Last Post: 19th October 2007, 15:42
