Thread: vvti, more problems.
    Mar 2011
    belfast
    confused vvti, more problems.
    hi everyone,
    i drive a 1.8 vvti sri 2006 with 150k, "Z18 XER ENGINE"
    having some problems lately.
    renewed the timing belt the other day along with camshaft and crankshaft seals.
    at first the car was fine then EML came on and then i started noticing that their was very little power in first and second gear.
    also 5 mins after starting the car, a rattle appears to come from the top of the engine,
    when we topped up the oil it went away then came back again.
    i done the peddle test and got these codes,
    0011 = A camshaft position, timing over advanced/system performence.
    0014 = B camshaft position, timing over advanced/system performence.
    0100 = mass or volume air flow malfunction.
    0110 = intake air temperature circut malfunction.
    0170 = fuel trim malfunction.
    we thought that maybe the timing was out a tooth but when we checked it, it was fine.
    we done a compression test and got these readings.
    cylinder 1 = 9.5. "timing belt end"
    cylinder 2 = 9.5.
    cylinder 3 = 9.5.
    cylinder 4 = 7.5.
    these reading are the same readings i got 4 months ago and car was running fine then???
    has anyone any ideas????
    Mar 2011
    belfast
    confused
    just a wee update,
    i done another peddle test their and the code 0170 is no longer showing???
    if the VVT oil control valves were shot, would it show these symtoms?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Sure someone else has this lack of power on the vvt just this week or last. Sure it was a solenoid.
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Barrow In Furness, Cumbria
    Yeah, that was mine. I had no power in any gear. Also different fault code.
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. 1.8 VVTi (55)
    By don23 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd October 2011, 11:33
  4. What is meant by 1.8 VVTI? is the vvti engine better or worse?
    By Deann in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2011, 11:19
  5. 1.8 VVTI More HP????
    By krd0707 in forum Petrol Engine related
    Last Post: 23rd December 2009, 23:38
