Thread: 1999 T reg corsa service advice
    Full Member
    Nov 2009
    Warrington
    Default 1999 T reg corsa service advice
    hey guys, seemed to have landed myself a job doing a service on my wifes bezzie mates car. shes just bought it and its no service history so said i would do oil change etc its a 1999 t reg corsa 1.2 16v. ive serviced my cars ive owned and also done a lot of friends and family, but never on a corsa. i guess ill do an oil and filter air filter plugs and maybe coolant change and fuel filter. simple jobs i know but is there anyone who has experiance with these cars and also servicing them, thanks. rob
    Regular Member Toe-side's Avatar
    Dec 2011
    Northumberland
    Easy to work on cheap and plentiful parts, new and second hand.
    How noisy is the chain on the cam drive? If the chain is noisy and it breaks then the engine is toast.
    Cam chain and sprocket replacement is a fun packed job.
    Full Member
    Nov 2009
    Warrington
    Quote Originally Posted by Toe-side View Post
    hey buddy, to be honest ive no idea as i havent even looked under the bonnet yet, anything like replacing the chain i prob would get involved with so i would just advice her to get it done, but things i know i can do like filters and plugs would save her having to pay someone to do it saving her money to get the chain done if needs be, i could do with having a look at some pics (haynes manual style) if anyone knows of any sits i can look at.
    Dec 2011
    Northumberland
    Check out the corsa forums for hints and tips. Its all straightforward on the servicing side of things TBH. Haynes manual is the usual, some times good some times ok
    Good youtube on the chain replacement if you are into mechy things (its an Agila but same engine). Some guys to a really good job on these sort of things.
    [ame="http://www.youtube.com/watch?v=w39GHIFmVaQ"]Agila timing chain z12xe replacement - YouTube[/ame]
    Full Member
    Nov 2009
    Warrington
    cheers ill have a look at the video. if it was my own car i would prob give it a go but as its not i doubt ill be doing it haha. im handy with spanners like but dont think ill risk it. how can you tell if the chain is on its way out, at what milage do these have to be replaced, as said before ill do the easy bits ie filters and oil antifreeze plugs etc but ill advice her to have that chain looked at. cheers
    Dec 2011
    Northumberland
    They are noisy! Check Youtube again for some examples. Seem to suffer from using crap oil or not changing it regularly enough. I was advised to change my son's at about 92 K but some go a lower miles some alot higher. You just get a rattling engine speed related noise from the cam drive side. It takes quite a while to actually get to the chain aux drives, water pump, remove engine cover (numerous fastners) etc. Enjoy the servicing!
    Full Member
    Nov 2009
    Warrington
    cheers for the advice buddy, i knoiw what to listen out for now. many thanks. rob
    wirral
    58 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As above check for chain noise.
    Also of its got mayo under filler cap etc. don't assume it's head. They suffer water pump gasket problems.
    If you do decide to get brave I've got the timing tools your more than welcome to borrow.
    You'll be looking at about 4 hours to do it.
    Also need to check underneath, sub frame axle mounting point etc for rust.
    Get the rear drums off and check the friction material and also the cylinders.
    wirral
    58 Post(s)
    Trim : Basic
    Engine : 1.9
  1. Service advice
    By GAV_SRI in forum Vectra C / Signum Troubleshooting
    Last Post: 4th May 2012, 01:12
  2. Replies: 14
    Last Post: 27th February 2011, 00:14
  3. Service Advice
    By hbweb in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2009, 23:21
  4. Service advice please
    By mishima in forum Vectra C / Signum Car Chat
    Last Post: 3rd January 2009, 23:43
  5. Corsa service....
    By Harry in forum General Chat
    Last Post: 17th January 2007, 20:47
