Results 1 to 10 of 14
Thread: Insignia rattling upon cold start
    Regular Member mark_l's Avatar
    Mar 2012
    Israel
    Default Insignia rattling upon cold start
    Hi all!
    I am new here and here is my problem:
    [ame="http://www.youtube.com/watch?v=TG-tXO7nEYU"]Noise 26022012.mp4 - YouTube[/ame]
    Tried to find discussions in the forum, but nothing find about Insignia.
    Thanks ahead for directing me to right place on this forum.
    Concerning the issue:
    On different forums there are two main opinions: or VVT or chain.
    IMHO it is VVT, because in 99% the noise appears upon COLD start-up.
    How it is built? What is a reason? What parts are knocking? How danger is it? How to resolve this problem?
    Our local Opel representative says that it is absolutely normal.
    For me it is hard to believe.
    Can anybody help?
    Thanks ahead.
    NB. It is about A2.0NHT Turbo engine on Edition 2011, 10 KKm.
    PS. it makes me crazy...
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    It could be your chain/tensioner mate. Is the 2.0T a VVT on the Insignia? If so check your oil levels as well, the VVT needs to be kept topped right up with oil.
    Regular Member VVT-i-MATT's Avatar
    Feb 2012
    Calne UK
    Yes what engine is it? the 2.0T, I didn't think was a VVT... could be wrong though.
    Either way the cam phasers/actuators/motors whatever that are called this week. Starved of oil normally on the VVT.
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by VVT-i-MATT View Post
    Insignia mate not Vec m8.
    A turbocharged direct injected (redubbed Spark Ignition Direct Injection) Ecotec was introduced in the 2007 Saturn Sky Red Line. Displacement is 2.0 L — 1998 cc (121.9 cu in) — with a square 86 mm (3.38 in) bore and stroke. Compression is 9.2:1 and maximum boost is 20.0 psi, delivering 260 hp (194 kW) at 5300 rpm and 260 lb·ft (353 N·m) of torque from 2500–5250 rpm. Engine redline is at 6300 rpm and premium fuel is recommended. The "Gen II" block is similar to the 2.4 L and also features VVT technology.
    Unique LNF features[1] include:
    * a twin-scroll turbocharger
    * gasoline direct injection
    * variable valve timing
    * sodium-filled valves
    * oil-cooled low-friction cast pistons
    This engine is used in:
    Mar 2012
    Israel
    Thank you, rushy for prompt reply!
    If it is chain-why the noise almost not appears the engine is hot? what the difference for chain "to scream" when hot?
    Yes, it is 2.0 Turbo engine (sorry-I edited it ), topped with oil up to upper mark.
    Jan 2010
    glasgow
    2011 and 10kkm thats what 5-7k miles uk thats mega low miles to start having probs if its got a dephaser pully they dont normaly go till near 30 k i havent got sound on this pc so cant have a listen you could try giving it a oil change see if that helps, benny is prob your best guy to ask to have a listen to it oh hang on is it a rattle or a scream? if its screaming it could be a aux belt tentioner
    Mar 2012
    Israel
    Quote Originally Posted by hoochydady View Post
    That's exactly what makes me crazy, mate! first time this noise appeared in first days at 1 KKm on clock, when oil was clean like tear...
    Thanks for advice, I'll try to find Benny
    Mar 2012
    Israel
    It could be your chain/tensioner mate....
    If so-may be the situation is not so bad?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Surely this car is under warranty, 2011 and low mileage
    Mar 2012
    Israel
    Sure! But what can I do when they say "it's ok, you may continue to drive"?
  1. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  2. cold start
    By abz123 in forum Engine & Drivetrain
    Last Post: 15th October 2012, 22:24
  3. 2.2 dti cold start
    By tomo610 in forum Diesel Engine related
    Last Post: 2nd January 2011, 10:47
  4. Cold start
    By bigmac in forum Engine & Drivetrain
    Last Post: 30th January 2009, 13:15
  5. Cold Start
    By T4M in forum Engine & Drivetrain
    Last Post: 10th July 2007, 20:47
insignia diesel engine rattle
vauxhall insignia rattle when start up
opel insignia 2009 rattling noise on cold start
vauxhall insignia 2011 noise when engine is cold petrol
vectra c 2.0 t engine rattle
insignia 2.0cdti knocking at cold start
vauxhall insignia noise when engine cold
insignia cold start noise
vauxhall insignia noisy when starting
vauxhall insignia making noise when starting from cold
rattle when starting vauxhall insignia
vauxhall insignia 2.0 cdti noisy engine starting cold
diesel rattle on new insignia
insignia cdti rattle when cold
opel insignia when cold
insignia letting clatter out on cold start
insignia engine noise when cold
vauxhall insignia engine rattle
2011 vauxhall insignia cold start noise
Engine rattle start up when cold 2.0L signum
insignia vxr cold.start
insignia rattle noise
vauxhall ecotec rattle on cold start
vauxhall insignia rattling
vauxhall insignia 2014 rattling when cold
