Thread: Went to get fault codes read...
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    Default Went to get fault codes read...
    ...and the diagnostics machine the garage had couldnt pick up my car! The guy said that had only hapened once before and it was on a ..........wait for it..........Vectra C that had been remapped. He asked if mine had been remapped but is far as im aware its standard.
    Anyways, he said to take it back in tomorrow morning and he will bring his own laptop in as he thinks he can hook it up to that and do it!
    Fingers crossed
    Nov 2011
    Akrotiri, Cyprus
    Off back to the garage shortly. I wonder why the car could not be recognised on the system? Wierd
    Full Member
    Mar 2011
    n. ireland
    keep us informed, this looks like a good mystery story
    Nov 2011
    Akrotiri, Cyprus
    Just got back from the garage, it worked this time but the guy had to enter the manufacturer as Opel instead of Vauxhall before it would pick the car up? Strange!
    Anyways, its the DPF thats the problem. He said its the cause of alot of problems he has seen with cars that have them. Its also throwing up an exhaust temp sennsor code but thats caused by dpf being knackered!
    He recommended taking it off and blasting it through with a jet wash? That might sort it for 6 months or so but ideally i should think about having it removed.
    What a pain in the hoop!
    Im wondering if its worth biting the bullet and getting ben at MAS to blank the egr, remove dpf and remap....he quoted me £310.
    There is also a glow plug fault too, think i should be able to change them myself tho and they are reasonably cheap i think!
    At least i know what the problems are now tho!
  1. connecting to the car to read fault codes etc
    By 1ctchris in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2009, 15:03
  2. Just Read Fault Codes Help! 3.0 CDTi
    By m300raj in forum Engine & Drivetrain
    Last Post: 6th December 2009, 18:55
