Thread: Air Intake hose leaking oil
    Regular Member JamesGTB's Avatar
    Jul 2009
    Default Air Intake hose leaking oil
    Hi everyone
    I have recently noticed oil runs on the sump tray of my 150 CDTI so with investigation traced it back to the main air inlet hose that leads to the inlet manifold.To be exact it is leaking from the jubilee clip joint where the rubber hose meets the hard plastic joint. After removing the hose there seems to be alot of oil in it which in turn is leaking from the joint - should there be this much in there or is manifold blocked etc?? Car is running fine at the mo apart from this dripping. Any ideas??
    PRESTON
    It's normal for oil to be in the inlet hose. it comes from the breather system as oil mist and as it passes though the intercooler it condenses back into oil. This is the main cause of egr valves becoming clogged with carbon and why some people look at modifying the breather system. As it is a diesel, the engine normally burns this oil with no ill effects, so if the car is running fine i would just renew the clip or pipe if it's split.
    Jul 2009
    Hi
    Thanks for the reply & confirming.I thought oil would be present but wasn't sure on the amount.
    Jul 2009
    Hi
  1. intercooler hose leaking oil 1.9 cdti 150
    By sr_fly in forum Vectra C / Signum Troubleshooting
    Last Post: 4th September 2012, 08:21
  2. TB Intake - Silicone Hose Colour?
    By Leemarksmith in forum Styling
    Last Post: 14th June 2012, 20:04
  3. Hose connections / Air intake?
    By Leemarksmith in forum Engine & Drivetrain
    Last Post: 2nd June 2012, 12:08
  4. Air intake hose missing?
    By felixx in forum Diesel Engine related
    Last Post: 17th July 2010, 22:29
