Thread: vectra 2.0 turbo strange strong smell from exhausts
    Regular Member matrix1979's Avatar
    Aug 2007
    NORFOLK
    Default vectra 2.0 turbo strange strong smell from exhausts
    Hi people i have a vectra 07 plate 2.0 turbo z20net engine , im not sure if someone can help me but here goes . ive recently notticed that ive got a strong smell coming out of the rear back boxes its hard to describe the smell but its like oily petrol smell , i dont think its the cat as it dont smell of rotten eggs . but ive notticed that my lumpy tick over is getting worse as its now does it when cold ,if someone can help i will appreciate it as im kinda getting worried thanks mark .
    Aug 2007
    NORFOLK
    would it have any thing to do with the maf sensor at all as im sure my miles per gallon has dropped plus the other day when i went to start the car it was like it was going to stall on me and hardly no acceleration plus driving along like a kangeroo effect ( hesistating really bad )then after 500 yrds travelling it went away :S
    Aug 2007
    NORFOLK
    bump
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Coudl it be the Turbo seals have gone and its dumping oil into the engine
    Aug 2007
    NORFOLK
    can i check this from looking from the outside looking in merikiito?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    You would need to remove the hoses connected to the turbo and check for oil I think.
    South east
    Also check the oil level - if you knew it was fine before and it's dropped now, that'd be an indicator.
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    remove your lambda sensors and give then a good clean as well... you have two, one in the bend of the downpipe just past the turbo and the other is in the exhaust mid section..
  1. Strong Exhust Smell in car - just started happening!!
    By suresh.chohan in forum Engine & Drivetrain
    Last Post: 17th December 2012, 20:39
  2. Strong Exhust Smell in car - just started happening!!
    By suresh.chohan in forum Introduce yourself.
    Last Post: 17th December 2012, 18:34
  3. strong smell of diesel
    By marky2027 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st January 2012, 15:52
  4. veccy diesel strong smell when starting up
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 12:05
  5. Strong Diesel Smell
    By DeathStar in forum Diesel Engine related
    Last Post: 2nd December 2007, 16:54
