Results 1 to 10 of 18
Thread: Interior light bulbs
    Regular Member *rob*'s Avatar
    Mar 2011
    Club-vaux, Moderator
    Engine : Y30DT
    Default Interior light bulbs
    What are they? Wanting to change mine to LEDs, also do they need to be canbus compliant?
    Regular Member rockafella8587's Avatar
    Nov 2011
    Akrotiri, Cyprus
    I used these http://www.ebay.co.uk/itm/2-x-8-LED-...item43a92b4781 for the ones in the light panel on the roof. I dont think the interior bulbs are connected to the canbus system anyways tho so no worries!
    The ones in the boot are different tho http://www.ebay.co.uk/itm/CANBUS-FES...item4ab4930117
    May 2011
    bispham, blackpool
    their 501 bulbs i have green led's in mine front and back just standard 501 leds off ebay and i bought bright white ones for the map so if i needed to see inside the car more clearly i can put map lights on and see
    edit the link above are the same type as i have in bright green
    Mar 2011
    Engine : Y30DT
    Cheers guys, just ordered some
    Berkshire
    Do LEDS still fade out like the original bulbs in the interior light after the door is closed? And I'm being lazy, as I could check but is it two bulbs I need for the interior front light?
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Yes the leds will fade out the same and there is two bulbs for the front light.
    Nov 2011
    Akrotiri, Cyprus
    Yes mate there is 2 for the normal light that comes on when you unlock the car / open door etc and another 2 the same for the map lights. so 4 in total for that cluster.
    And yes, they fade when they go out like the normal bulbs do
    Berkshire
    Thanks to both of you for the answer
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I found if you get the inverted lense LED 501s it spreads the light better and you don't get the spot light effect on the lense...
    Jan 2010
    Staines, Middx
    and am i right in thinking LEDs for interior lights cause no strobing/error messages?
  1. interior light bulbs
    Last Post: 3rd January 2011, 21:42
  2. interior light bulbs what to go for????
    By vectragsi3.2 in forum Styling
    Last Post: 13th April 2010, 19:55
  3. Interior light bulbs
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2009, 12:40
  4. Bulbs & interior light. FS.
    By Caterman in forum Parts for sale
    Last Post: 7th September 2007, 00:38
  5. Removing interior light bulbs on SRI - er how???
    By stehanson in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 15:48
