Results 1 to 10 of 25
Thread: One for the MOT testers...
    Regular Member Samdy Gray's Avatar
    Jul 2009
    Wiltshire, UK
    Default One for the MOT testers...
    I've searched the forum but couldn't find anything similar.
    I know that it's now an MOT failure if the EML/MIL is present for one of the safety systems (e.g. airbags, power steering, brakes etc.), but what about for a glow plug fault?
    The reason I ask is my MOT is due soon, I have the MIL present for what I assume is a glow plug fault (my U480 won't read the code so it's electrical not an engine fault) that I don't really have the inclination to get fixed right now. Car starts and runs absolutely fine.
    spoke to a mot tester on wed and he said any warning light will fail an mot after 1st april this year
    Ashington, Northumberland
    I am a tester and Mark is correct, ANY warning light will result in a fail.
    Jul 2009
    Wiltshire, UK
    Dammit. Looks like I'm going to have to get my glow plugs sorted then.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So airbag light on will be a fail now?
    Vehicle : Jaguar S-Type V6
    Trim : Sport
    Engine : Petrol
    what warning light do you get?
    I ran with only 3 glow plugs working for years car spanner light would come on then go out after about 30-45 secs with no starting problems. I never had any problems with MOT's I only changed my plugs when starting became an issue about a month or so ago. I was down to only one plug working.
    Now all four work with no car spanner light.
    For what it costs its worth changing plugs once you get the light comming on though. I had no probs with MOTs in the past as the light is only on for a matter of seconds when stared then goes straight out.
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Quote Originally Posted by DTI-Steve View Post
    It was ok in the past for car spanner light to be on on but from April 1st this year it will be a fail. Manufacturers have got their way so they can rip off more money from us.
    Jul 2009
    Wiltshire, UK
    Yeah it's the spanner light.
    It only comes on when the engine is cold, once it's been ran for a while I can restart it without the warning light being present.
    I could just be crafty and take the car for a good run before the MOT, clear the code (my U480 will somehow still let me do this but not actually read the code) and then present it for the test. The light shouldn't come back on when the tester starts the ignition then.
    Or I could just get the plugs changed. Just took a look down the back of the manifold (I have the 120 CDTI) and it looks a right pig!
    Jul 2009
    Wiltshire, UK
    Edit: DP
    Quote Originally Posted by Samdy Gray View Post
    Very unlikely, as the MoT tester will normally let the car sit and cool down, before touching it
    You could chance it, see what happens
    On the plus side, if it only fails on the warning light, you could then ask them for a quote (they might even say "Sorry we don't read fault codes") or take it away, have all the glowplugs replaced, then retest on that failed point
  1. MOT Testers - Help!
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 26th March 2011, 09:09
  2. PAT testers
    By DaveDempsey in forum General Chat
    Last Post: 13th August 2009, 09:09
  3. Mot Testers Manual
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 7th November 2008, 15:36
  4. How do you use one of these antifreeze testers?
    By muffking in forum Engine & Drivetrain
    Last Post: 10th January 2007, 14:19
  5. Testers needed
    By Spikey© in forum General Chat
    Last Post: 8th November 2006, 14:11
