Thread: Brake pad wear indicator
    Sep 2009
    Gateshead
    Vehicle : Vectra C Estate
    Trim : Sri
    Engine : 1.8i VVT
    Mileage : 64000
    Default Brake pad wear indicator
    Hello all,
    I changed rear discs and pads 2 days ago and now the brake pad wear indicator came up on dashboard. I never touched the front brakes at all.
    Anybody has got any experience with this problem. I changed front break pads last year there is no chance these are worn up.
    Ely, Cambridgeshire
    60 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The wear indicator is on the front passenger side wheel (there isn't one on any of the other wheels), so either your front pads have worn or the connector has become dislodged or broken. It's also possible you may have had a pad come away from it's backing although you should have heard the horrible grinding noise that accompanies this when it happens
    Quote Originally Posted by Ian-Highlander View Post
    The wear indicator is on the front passenger side wheel only
    The pad indicator can also be displayed (depending on car type) with low brake fluid
    Mine does this also
    Odd! low brake fluid should put on the handbrake lever warning light.
    Yes, but it there is an option when you have the Drivers Info Centre to have the handbrake lever as that only, Low Brake Fluid warning then shares the Brake Sensor warning
    I had to check my handbook to see why it was on, as there was loads of front nearside brake pad remaining
  1. Brake wear sensor put where?
    By kenp in forum Suspension, Wheels & Brakes
    Last Post: 28th August 2012, 23:33
  2. brake pad wear sensors?
    By marwen in forum Vectra C / Signum Car Chat
    Last Post: 26th August 2011, 12:01
  3. Brake Pad Wear Indicator
    By barachello in forum Suspension, Wheels & Brakes
    Last Post: 16th May 2011, 18:11
  4. brake pad wear indicator?
    By amar in forum Handling & Braking
    Last Post: 6th April 2008, 00:36
  5. Brake Pad Wear Indicator
    By Hendry in forum Vectra C / Signum Car Chat
    Last Post: 10th September 2007, 19:51
