Results 1 to 10 of 14
Thread: Flippin' Vauxhall!!
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Default Flippin' Vauxhall!!
    I've had the power steering warning light on my dash for about 2 years now & with the mot rules about to change I thought I had better get round to getting it fixed. Read the fault codes & got C1534, which from what I can gather from some of the foreign forums is power steering fluid level. The level is fine, so I thought I'd try a new sensor. Ordered the part from the dealers tuesday, paid £52.38 for it, went to collect it today only to be told Vauxhall 'no longer service that part' - basically they don't make it anymore!! How can they stop making a part for a car that was only released 10 years ago! (I think I know the answer, probably involves a new PAS pump). They said they would check their dealer network tomorrowto see if somewhere has one in stock but otherwise they can't upply the part.
    Basicallly I can't find this part anywhere online. I've tried ebay & all the usual online parts places but nowhere has one. If I can't get one from a scrappy or local motor factors I'll have to buy a complete pump & sensor off ebay.
    Can anyone suggest somewhere that might sell one? Failing that does anybody know If this sensor can be programmed out via Tech2 & if the dealers would do this for me?
    Any advice appreciated
    Regular Member Stan-H-'s Avatar
    Sep 2010
    Middlesbrough
    Tried a scrap yard bud? often a good place for spares
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    I will next week, I just haven't had the time. The dealers is literally 2 minutes away so like an idiot I thought it would be less hassle to go to them direct.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well I know what the problem is!
    The car has had a new power steering pump. The old pumps had a level indicator and the new ones do not. VX should know this because when they fit a new one they have to tech 2 the level indicator out if the car had the one with the level indicator.
    so the answer is go get it tech2'd out, problem solved.
    New Member melvyn8181's Avatar
    Jul 2011
    north lincolnshire
    Power steering light wont fail mot, only eml,
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    As far as I know the car has the original pump because it has got a level sensor on it. If it can be tech2 out I would prefer to do that rather than take the front of the car to bits.
    It say on direct gov the test includes 'Check of the MIL for electronic power steering and steering lock.' Will they definately not fail the car for this?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by dave300776 View Post
    Yes you can tech 2 it out, is the level sensor built into the lid?
    Regular Member fiend61's Avatar
    Nov 2011
    york
    Vehicle : vectra 2.8 turbo
    Trim : elite
    Engine : 2.8 turbo
    intead of going for the cost of a tech11 cant you just short out the wires so they are making contact all the time ?????
    Wigan
    Trim : Exclusive
    Engine : 1.9 CDTI
    Quote Originally Posted by merikiito View Post
    The sensor looks like it screws or pushes into the top of the reservoir next to the filler cap.
    Quote Originally Posted by fiend61 View Post
    I tried this. With the sensor plugged in or disconnected I get a pending C1534 code, with the wires shorted the code changes from pending to stored & the mil is still on.
    Vauxhall have just rang & told me there isn't a dealer in the country with this part. They said they can Tech2 the sensor out as Merikiito says but it would cost £65. They gave me the number of a local auto electrician who they say might be able to repair the sensor or deprogram it cheaper than them.
    They also said if your car is over 6 years old & a mil is caused by a defective but discontinued part it should not fail an mot on that alone. Never heard of that one before!
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Someone local with VauxCom who can help???
  1. Flippin Heck...
    By macdad in forum The 'Off Topic' room
    Last Post: 11th January 2012, 21:02
  2. Flippin Heck!! How Much?????
    By Ian-Highlander in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2010, 19:32
  3. Flippin RAIN !!!
    By spennny in forum The 'Off Topic' room
    Last Post: 27th November 2009, 13:42
  4. I'm not that flippin' old!
    By SignumPhil in forum General Chat
    Last Post: 20th March 2009, 17:38
